Antenna Bar
crwdns2933313:01crwdne2933313:0 crwdns2934263:02crwdne2934263:0 |
Can the SSD be replaced |
crwdns2933313:01crwdne2933313:0 crwdns2934263:00crwdne2934263:0 |
Bought a used MacBook, has someone been inside it? |
crwdns2933315:02crwdne2933315:0 crwdns2934263:01crwdne2934263:0 |
Battery for A2992: can I use the one for A2442, A2779, A2918 |
crwdns2933313:01crwdne2933313:0 crwdns2934263:01crwdne2934263:0 |
Possible Liquid metal application? |
A2992 (MacBookPro15,10 Late 2023) M3 Max 14 CPU/30 GPU, A2992 (MacBookPro15,6 Late 2023) M3 Max 16 CPU/40 GPU, A2992 (MacBookPro15,6 Late 2023) M3 Pro 11 CPU/14 GPU, A2992 (MacBookPro15,6 Late 2023) M3 Pro 12 CPU/18 GPU
Background
Released in November 2023, the latest 14" MacBook Pro gets an upgrade with Apple's also-new-for-late-2023 M3 Pro and M3 Max SoCs, featuring up to 12-core or 16-core CPUs and up to 18-core or 40-core GPUs respectively. Both the updated 14" MacBook Pro and its bigger 16" MacBook Pro sibling share many of the same features found in early 2023 MacBook Pros, including the same ports, ProMotion HDR mini-LED displays, 1080p webcams with a display notch, full-size function keys, and the distinctive blacked-out keyboard. Small, yet notable other upgrades for late 2023 include a slightly larger battery and a new color option—Space Black.
Starting at a price of $1999, the late 2023 14" MacBook Pro with M3 Pro and M3 Max is available in either Silver or Space Black.
Identification
Identify your MacBook Pro by the model number printed on its back cover.
You can also find the model number through macOS by choosing About This Mac from the Apple menu in the upper-left corner of the screen.
Additionally, Apple offers a quick online tool to help identify your devices: Identify your MacBook Pro model.
The late 2023 MacBook Pro with M3 Pro and M3 Max can be differentiated from the nearly identical late 2023 MacBook Pro with M3 by the ports along the right edge. The base model M3 has no USB-C ports, while models with M3 Pro or M3 Max have one. If the laptop is Space Gray, it is a base model M3 model. If it's Space Black, it's an M3 Pro or M3 Max model. If it's Silver, check the number of USB-C ports.
Technical Specifications
Display
- 14.2" Liquid Retina XDR mini-LED display with True Tone; 3024 x 1964 pixels (254 ppi); ProMotion adaptive refresh rate (up to 120 Hz); HDR, P3 wide color gamut; 1000 nits sustained, 1600 nits peak brightness
Processor
- Apple M3 Pro 11-core CPU, 16-core Neural Engine
- (Configurable to) Apple M3 Pro 12-core CPU, 16-core Neural Engine
- (Configurable to) Apple M3 Max 14-core CPU, 16-core Neural Engine
- (Configurable to) Apple M3 Max 16-core CPU, 16-core Neural Engine
Graphics
- Apple M3 Pro integrated 14-core GPU
- (Configurable to) Apple M3 Pro integrated 19-core GPU
- (Configurable to) Apple M3 Max integrated 30-core GPU
- (Configurable to) Apple M3 Max integrated 40-core GPU
Storage
- 512 GB PCIe-based SSD, configurable to 1 TB, 2 TB, 4 TB, or 8 TB.
Memory
- 18 GB of unified LPDDR5 memory, configurable to 36 GB, 48 GB, 64 GB, 96 GB, or 128GB depending on configuration
Wireless
- 802.11ax Wi-Fi 6E wireless networking; IEEE 802.11a/b/g/n/ac compatible
- Bluetooth 5.3 wireless technology
Battery
- Built-in 72.4-watt-hour lithium-polymer battery
- Up to 12 hours of web browsing, up to 18 hours of Apple TV app video playback
Dimensions
- Height: 0.61 in (1.55 cm)
- Width: 12.31 in (31.26 cm)
- Depth: 8.71 in (22.12 cm)
- Weight: M3 Pro: 3.5 lbs (1.61 kg), M3 Max: 3.6 lbs (1.62 kg)
Ports
- MagSafe 3 charging port
- 3× Thunderbolt USB-C ports (Thunderbolt 4 / USB 4 / DisplayPort / charging)
- HDMI 2.1 port
- SDXC card slot
- 1× 3.5 mm headphone jack
