crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
Background
The Logitech Z606 5.1 Surround Sound Speaker System is an affordable, entry-level home/PC surround system that offers 5.1-channel audio and Bluetooth streaming. The speaker enclosures use durable ABS plastic housings with cloth-covered satellite grilles and a reinforced MDF-like cabinet for the powered subwoofer to resist wear. Key features include a powered subwoofer, five satellite speakers, a wired control pod with volume and input selection, and multiple input options (Bluetooth, RCA, 3.5 mm AUX). The system is designed for simple setup and loud, room-filling output for movies, games, and music.
Identification
The Logitech Z606 5.1 SurroundSound with BT can be identified by the model number (M/N RI0004). The model label is on the underside/rear of the subwoofer and on the control pod housing. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Channels: 5.1 surround (5 satellites + 1 subwoofer)
  • Total Power (Peak): 160 W (manufacturer-rated peak power)
  • Total Power (RMS): Approx. 80 W RMS (manufacturer-stated combined output varies by region)
  • Connectivity: Bluetooth (wireless), RCA stereo inputs, 3.5 mm AUX input (wired)
  • Bluetooth Version: Bluetooth 4.x (manufacturer lists Bluetooth streaming support; exact minor version not published on support page)
  • Subwoofer: Active powered subwoofer, downward-firing driver (approx. 6-inch driver, model unspecified)
  • Satellite Drivers: Five compact satellite speakers with small full-range drivers (cloth grille; individual driver model numbers not published)
  • Control Pod: Wired control pod with volume knob, power, and input selection buttons; wired connection to subwoofer and satellites
  • Key Switches / Buttons: Membrane/buttons on control pod (no mechanical key switch manufacturer listed; N/A for mechanical key switches)
  • Included Components / Cables: 1 × powered subwoofer, 5 × satellite speakers, 1 × wired control pod, speaker cables and audio input cables (RCA and 3.5 mm), power cable
  • Frequency Response: Manufacturer does not publish a full spec; typical consumer range ~40 Hz–20 kHz (system-dependent)
Troubleshooting
Common repair-relevant faults include no sound from individual satellites (often loose speaker wiring), distorted or no bass (subwoofer power or internal fuse issues), and Bluetooth pairing/dropouts (antenna or module faults). Diagnose by verifying power LED and control pod settings, swapping speaker leads to isolate faulty satellite or cable, testing with wired input to rule out Bluetooth, and checking internal wiring and solder joints in the subwoofer and control pod.
For additional troubleshooting help, visit: Contact Logitech Support for product help and warranty claims: https://support.logi.com/hc/en-us/articl...
Additional Information
Warranty Info
Check Logitech warranty pages for region-specific coverage; Logitech typically provides a limited hardware warranty (contact support for scope and duration).
Tim Asp
crwdns2935283:001/24/11crwdne2935283:0
42.335 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 171
