crwdns2933307:0crwdne2933307:0 crwdns2934263:00crwdne2934263:0 |
Why is there no sound in the speaker?(logitech z213 speakers) |
Background
The Logitech Z213 Compact 2.1 Speaker System is a small-form-factor desktop speaker set designed to deliver clear audio and enhanced bass for compact workspaces. It uses a wired 3.5 mm (0.14 in) analog connection and includes a wired control pod for easy access to power, volume, and a headphone jack. The system is built with a durable plastic chassis and components designed for everyday use, and the subwoofer is sized to fit under a desk to save surface space. Logitech’s product page emphasizes simple controls and sustainability considerations in the product design.
Identification
The Logitech Z213 Compact 2.1 Speaker System can be identified by the model number (M/N S-00143). The model label is on the underside of the subwoofer; the wired control pod is inline on the speaker cable. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
- Form Factor: Compact 2.1 (satellites + subwoofer)
- Model / SKU / MPN: Z213 / 980-000941 / productID: z213-compact-speaker-system
- Connectivity: 3.5 mm (0.14 in) wired analog input
- Control Pod: Wired control pod with power, volume knob, and headphone jack
- Channels: Stereo satellites + active subwoofer (2.1)
- Materials: Durable plastic chassis and components (designed for everyday desktop use)
- Compatibility: Works with PCs, Macs, and mobile devices with 3.5 mm audio output
- Item Condition / Availability: NewCondition (as listed on product page); price example CAD 49.99
- Key Switch Manufacturer: N/A (not applicable for speaker system)
Troubleshooting
Common repair-relevant faults include no audio (often caused by cable or control pod failure), intermittent sound (damaged cable or loose internal solder joints), and distorted/bass-less output (blown driver or failed amplifier). Diagnose by verifying 3.5 mm connections and source device, testing with a known-good cable or device, inspecting the control pod and cable for visible damage, and using a multimeter to check continuity and power to the amplifier/subwoofer.
For additional troubleshooting help, visit: https://support.logi.com — contact for product support, warranty claims, and help articles.
Additional Information
Warranty Info
Check Logitech warranty information on support.logi.com; warranty varies by region.
Logitech Multimedia Speaker Z213 Setup Guide
Logitech Z213 Compact 2.1 Speaker System Setup Guide (EN, FR)
