crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
Background
The Z211 USB Powered Speaker is a compact two-piece stereo speaker system from Logitech designed for simple desktop audio. It features durable plastic housings and robust external cabling engineered for everyday use. Key features include USB-powered operation (no external AC adapter), an attached 3.5 mm auxiliary input for universal audio sources, and an inline volume control on the main speaker. The design prioritizes easy plug-and-play connectivity and space-saving placement on a desk.
Identification
The Logitech Z211 USB POWERED SPEAKER can be identified by the model number (M/N S-00160). The model label is on the underside of the right/main speaker. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Manufacturer: Logitech
  • Model: Z211
  • Release type: Retail consumer desktop stereo speakers
  • Connectivity: Wired 3.5 mm auxiliary input (attached cable)
  • Power: USB powered (5 V via attached USB power cable) — connects to USB port or USB power adapter
  • Configuration: 2.0 stereo (left and right satellite speakers)
  • Controls: Inline/side-mounted volume control on the main/right speaker (wired) — power/volume combined control is unit-dependent
  • Driver information: Driver size and detailed driver model not specified on Logitech support page
  • Spare parts / service: No spare parts or documentation listed on Logitech support page for this product (per Logitech support) — contact Logitech for warranty service
  • Included cables: Attached 3.5 mm audio cable and attached USB power cable (non-detachable)
  • Certifications & docs: No downloads or product documents listed on Logitech support page; check Logitech support for region-specific warranty details
Troubleshooting
Common faults include no power (usually caused by USB power issues) and no/uneven audio (usually caused by bad 3.5 mm connection or damaged speaker wiring). Diagnose by confirming USB power on a known-good port or adapter, testing the 3.5 mm input with another source/aux cable, swapping left/right connection checks, and inspecting internal wiring and driver connections if opening the speaker.
For additional troubleshooting help, visit: See Logitech Support: https://support.logi.com (product page: Use the Z211 speaker)
Additional Information
Warranty Info
Manufacturer warranty varies by region; Logitech typically provides a limited 1-year hardware warranty — check local Logitech support for exact terms.
Tim Asp
crwdns2935283:001/24/11crwdne2935283:0
42,335 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 224
