crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
Background
The Z200 Rich Stereo Sound (Logitech Z200 Stereo Speakers) are compact multimedia desktop speakers designed to deliver room-filling stereo audio with adjustable bass. Each speaker uses a powered active driver paired with a passive radiator to extend low-frequency response, and simple analog controls are located on the right speaker for easy access. The housings are made from durable plastic and designed for everyday desk use; the product is offered in two color variants (black and white). Key features include 5 W RMS per speaker (10 W peak), adjustable bass, a front-mounted headphone jack, and a 3.5 mm stereo input.
Identification
The Logitech Z200 Rich Stereo Sound can be identified by the model number (M/N S00181). The model label is on the underside label of the speakers. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Form Factor: Desktop stereo speakers, 2.0 configuration
  • Model Numbers / SKUs: 980-000850 (Black), 980-000851 (White)
  • Power: 10 Watts peak / 5 Watts RMS total (2.5 W RMS per speaker typical; marketed as 5 W RMS total)
  • Driver Configuration: Each speaker: 1 active/powered full-range driver
  • Passive Radiator: Each speaker includes one passive radiator for bass extension
  • Controls: Right speaker: volume control and adjustable bass control (analog)
  • Connectivity: Wired 3.5 mm stereo audio input (aux) with front-mounted headphone jack
  • Power Source: Mains-powered (integrated power cable to right speaker)
  • Colors: Black (980-000850) and White (980-000851)
Troubleshooting
Common faults are no sound (loose/failed audio cable or incorrect source selection), one-sided audio (damaged speaker cable or failed driver), and distorted output (clipped amplifier or blown driver). Diagnose by checking/repinning 3.5 mm connections, testing with a known-good source and cable, swapping left/right connections, and using a multimeter to check speaker continuity before replacing drivers or amplifier components.
For additional troubleshooting help, visit: For drivers, support articles, and contact options visit https://support.logi.com and reference the Z200 product page.
Additional Information
Warranty Info
Limited hardware warranty varies by region; check Logitech warranty terms on support.logi.com (typically 1 year in many regions).
Tim Asp
crwdns2935283:001/24/11crwdne2935283:0
42.335 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 290
