crwdns2934263:01crwdne2934263:0
Background
The Logitech Wireless Headset H600 is a compact on-ear wireless headset designed primarily for voice communications and casual multimedia use. It uses a USB nano receiver to provide a 2.4 GHz wireless connection and offers an adjustable boom microphone with noise-reduction for clearer calls. The headset is built from durable plastics and reinforced materials at common stress points to withstand daily use, and includes a rechargeable battery and onboard volume/mute controls as key features. Its lightweight construction and simple USB plug-and-play connectivity make it suitable for office and home setups.
Identification
The Logitech Wireless Headset H600 can be identified by its model number (M/N A-00032). The model label is on the underside product label. The device’s serial number (S/N) appears nearby on the same label.
Specifications
  • Form Factor: On-ear wireless headset
  • Model Number: H600
  • Connectivity: 2.4 GHz wireless via USB nano receiver (USB-A) — plug-and-play
  • Wireless Range: Up to ~10 meters (typical indoor range)
  • Drivers: 40 mm dynamic drivers (stereo) for voice and multimedia
  • Microphone: Flexible boom microphone with noise-reduction (cardioid/omnidirectional variant depending on batch)
  • Battery: Rechargeable Li-ion battery; typical talk/music time ~6 hours (varies with volume/usage)
  • Charging/Port: Micro-USB charging port and included charging cable
  • Impedance: ~32 Ω (nominal)
  • Compatibility: Windows and macOS (USB plug-and-play); may require Logitech software for advanced features
  • Weight: Approximately 70–80 grams (lightweight design)
Troubleshooting
Common repair-relevant faults include battery failure (headset not powering on), USB receiver connection loss, and microphone failure. Diagnose by checking charging port continuity and battery voltage, testing the nano receiver in a different USB port or system, and verifying microphone continuity/boom wiring and mute switch functionality.
For additional troubleshooting help, visit: Visit support.logi.com and search for "H600" for product-specific help, FAQs, and contact options.
Additional Information
Warranty Info
Limited hardware warranty varies by region; consult Logitech support for specific terms (typically 1-year limited warranty).
Logitech Wireless Headset H600 Getting Started Guide (EN, ES, FR)
Logitech Wireless Headset H600 Complete Setup Guide
Logitech Wireless Headset H600 Complete Setup Guide (EN, FR)
Logitech Wireless Headset H600 Setup Guide (EN, ZH, KO)
Logitech Wireless Headset H600 Quick Start Guide (EN, ZH)
Logicool Wireless Headset H600 取扱説明書
Tim Asp
crwdns2935283:001/24/11crwdne2935283:0
42,886 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 55
crwdns2959996:0crwdne2959996:0 363
