Background
The Logitech Z313 is a compact 2.1 speaker system that delivers balanced, rich sound tuned for everyday computer and multimedia use. It produces 50 watts peak (25 watts RMS) output and uses a compact subwoofer to enhance bass response. The system is built from durable materials such as reinforced ABS plastic housings and reinforced cabling to withstand regular desktop use. Key features include simple setup via a 3.5 mm audio input, easy front-mounted controls, and a sustainability-focused design.
Identification
The Logitech Speaker System Z313 can be identified by the model number (M/N S-00093). The model label is on the Logitech Speaker System Z313 can be identified by its model/sku (MPN: 980-000382) and product ID (z313-speaker-system-subwoofer). Satellite speaker labels are typically on the underside; the subwoofer label and regulatory information are on the back or underside of the subwoofer housing. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Form Factor: 2.1 desktop speaker system (two satellites + subwoofer)
  • Power: 50 Watts peak / 25 Watts RMS
  • Connectivity: 3.5 mm stereo input (works with any device with a headphone jack)
  • Model / SKU / MPN: z313-speaker-system-subwoofer / SKU 980-000382 / MPN 980-000382
  • Color: Black
  • Controls: Easy front/inline controls for power and volume
  • Subwoofer: Compact sealed subwoofer for enhanced bass
  • Sustainability: Designed for sustainability; materials and processes optimized per Logitech product page
  • Price (MSRP): $69.99 (USD)
  • Package Contents: Z313 speaker system (two satellites + subwoofer), attached audio cable and power cable (exact contents per regional packaging)
Troubleshooting
Common faults include no power, no audio output, or intermittent sound caused by faulty cables, connectors, or internal wiring. Diagnose by checking power connection and indicator, testing the 3.5 mm input with a known-good source and cable, and isolating the problem to either the subwoofer (power/amplifier) or satellites (driver/wiring) by swapping cables or testing speakers individually. Internal driver or amplifier faults require opening the subwoofer and inspecting connections, fuses, and solder joints.
For additional troubleshooting help, visit: Visit https://support.logi.com for product support, contact options, and troubleshooting articles.
Additional Information
Warranty Info
Limited hardware warranty varies by region; see Logitech warranty information on support.logi.com (typically 1 year).
Logitech Z313 Speaker System Quick-Start Guide (EN, FR, ES)
Logitech Stereo Speakers + Subwoofer Z313 Getting Started Guide (EN, ZH, KO)
ロジクール Speaker System Z313 2.1ch アクティブスピーカー 取扱説明書
Logicool Z313スピーカーシステム (サブウーファー搭載) セットアップガイド
Logitech Z313 Speaker System with Subwoofer Complete Setup Guide (EN, FR)
Logitech Z313 Speaker System Complete Setup Guide (EN, ZH, KO)
Logitech Product Catalog 2010–11, Volume 3
Tim Asp
crwdns2935283:001/24/11crwdne2935283:0
42,886 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 37
crwdns2936753:030crwdne2936753:0 195
crwdns2959996:0crwdne2959996:0 1,327
