crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
Background
The PRO RACING WHEEL RIM is a competition-grade, bolt-on steering rim sold by Logitech G as an accessory for high-end PC sim racing setups. It is constructed from durable materials including a carbon-fiber face, anodized aluminum spokes/hub, and a high-grip Alcantara or leather wrap to withstand intense use. Key features include a quick‑release compatible hub, multi-function programmable buttons and encoders, and precision paddle shifters designed for fast, repeatable actuation. The rim is optimized for compatibility with Logitech direct‑drive and high‑torque wheel bases for professional sim racing.
Identification
The Logitech PRO RACING WHEEL RIM can be identified by the model number (M/N WU0013). The model label is on the rear hub assembly. This label lists the model (M/N), part (P/N), and serial (S/N) numbers.
Specifications
  • Form Factor: Removable competition-style steering rim (bolt-on) for direct‑drive and high‑torque bases
  • Materials: Carbon-fiber face, anodized aluminum spokes/hub, Alcantara or leather wrap (high-wear resistant)
  • Diameter: Approximately 320 mm (competition GT-style nominal size) — confirm on product label for exact variant
  • Buttons & Controls: Multiple programmable push-buttons, multi-position rotary encoders and a center D-pad (exact count varies by SKU; see product page)
  • Paddle Shifters: Dual machined anodized aluminum paddles with spring-return; paddle sensing implemented via contact/contactless sensors (manufacturer not publicly disclosed)
  • Switches: Proprietary Logitech micro-switches for buttons (manufacturer/model not publicly disclosed on product pages)
  • Interface: Proprietary quick-release hub connector compatible with Logitech G PRO wheel bases and select direct‑drive adapters
  • Compatibility: Designed for Logitech G PRO/Direct-Drive wheel bases on PC; requires compatible quick‑release mounting and firmware (see Logitech support)
  • Weight: Lightweight construction for direct‑drive use (manufacturer-quoted weight varies by finish/variant)
  • Mounting Hardware / Adapters: Ships with mounting hardware for Logitech quick‑release hubs; adapters or specific hub part numbers vary by region/SKU
Troubleshooting
Common repair-relevant faults include unresponsive buttons or paddles (often caused by loose hub connectors or worn switch contacts) and degraded grip material. Diagnose by inspecting and reseating the quick‑release electrical connector, checking continuity on ribbon/cable connections, testing button inputs through the wheel base/firmware, and replacing worn grips or the paddle assembly if mechanical damage is evident.
For additional troubleshooting help, visit: Visit support.logi.com and the PRO Racing Wheel product page on logitechg.com for drivers, firmware updates, and troubleshooting articles.
Additional Information
Warranty Info
Logitech provides region-dependent limited hardware warranty (typically 1–2 years). See product page or support.logi.com for specific regional warranty terms.
eCuration
crwdns2935283:005/19/17crwdne2935283:0
478.744 crwdns2915208:0crwdne2915208:0
crwdns2935297:0396crwdne2935297:0
Staff
crwdns2935297:072.895crwdne2935297:0
crwdns2936753:030crwdne2936753:0 50
crwdns2959996:0crwdne2959996:0 452
