crwdns2935069:011crwdne2935069:0
crwdns2933313:01crwdne2933313:0 crwdns2934263:00crwdne2934263:0 |
My NT 30/1 Tact te turns on then shuts down. What can cause this? |
NT30/1
Background
The Kärcher NT 30/1 Tact wet and dry vacuum cleaner is designed for cleaning of machines, vehicles, construction sites, and workshops. The vacuum has an automatic filter cleaning system and a moisture-resistant flat pleated filter for removing fine dust. The NT 30/1 Tact vacuum can collect both solids and liquids and store them in a 30-liter plastic container with a bumper and metal casters for durability.
The NT 30/1 Tact vacuum includes a flexible hose and power cable storage. The hose storage hook can secure hoses of different diameters and lengths. It also features a detachable filter casing that allows the user to replace the filter when necessary. The vacuum operates with an air flow rate of 74 liters per second.
The Kärcher NT 30/1 Tact wet and dry vacuum includes a 2.5-meter suction hose with a 360-millimeter wet and dry floor nozzle. It also comes with a crevice nozzle for operation in tight corners. The vacuum automatically switches off when the plastic container is full.
Identification
The Kärcher NT 30/1 Tact wet and dry vacuum can be identified by its great body with black wheels. It includes a yellow latch for opening the storage container and a yellow dial for controlling the air flow rate. The name “Kärcher” is printed in black capital letters above the name “Professional,” which is also printed in black font.
Technical Specifications
Current type (Ph/V/Hz): 1 / 220 / 240 / 50 / 60
Air flow rate (l/s): 74
Vacuum (mbar/kPa): 254 / 25.4
Container capacity (l): 30
Container material: plastic
Rated input power / Amps (W): 1380
Standard nominal width: ID / 35
Sound pressure level (dB(A)): 69
Weight without accessories (kg): 13.5
Dimensions (L × W × H) (mm): 560 x 370 x 580
