crwdns2935069:02crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
Background and Identification
The JET Pallet Jack PTW-2748 is a hand-controlled 27-inch by 48-inch pallet jack with a 6,000-pound loading capacity. It can be identified by the part number 140175. The pallet jack can be used for heavy-duty lifting of bulk quantities of material as well as loading or unloading box trucks. The pallet jack also includes overload protection that prevents lifting loads past its maximum capacity.
The JET Pallet Jack PTW-2748 features a 200-degree turning radius. It includes a top-stroke release valve that prevents cylinder extension beyond the jack’s maximum height. The jack also features a chrome-plated pump piston and ram that provide corrosion resistance in industrial environments. The one-piece cast iron pump has a built-in valve that lowers the material in a controlled descent to prevent injury.
The JET Pallet Jack PTW-2748 includes polycarbonate over aluminum 7- by 2-inch steer wheels that provide contact with uneven floors. The steer wheels feature double-sealed lubricated bearings. The pallet jack’s frame is solid welded steel that is powder-coated either a beige or grey color. It includes an 18-inch steel handle mounted to the center of the truck’s frame. The pallet truck features rounded fork tips to fit into pallet openings and prevent pallet damage.
Technical Specifications
  • Acme Tools Brand Name: JET
  • Acme Tools Part Number: 140175
  • Assembled Weight (lbs): 200
  • Assembly Required: Partial
  • Country of Origin: China
  • Depth (in): 59
  • Frame Material: Steel
  • Fully Welded Frame: Yes
  • Handle Length (in): 0
  • Handle Material: Steel
  • Height (in): 18
  • Internal Supplier Part #: PTW-2748
  • Internet Product Code (IPC): 12BB59F912D
  • MFG Model # (Series): 140175
  • MFG Part # (OEM): 140175
  • Manufacturer Warranty: 2 Year
  • Material: Steel
  • Product Name: 27 In. x 48 In. 6000 Lb. Pallet Truck
  • UPC: 662756180605
  • Weight Capacity (lbs): 6000
  • Width (in): 27
  • GlobalTradeItemNumber (GTIN): 00662756180605
Additional Information
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 119
crwdns2959996:0crwdne2959996:0 7,584
