crwdns2933315:011crwdne2933315:0
crwdns2934263:014crwdne2934263:0
crwdns2934263:01crwdne2934263:0
Background and Identification
Released in 2014, the Jabra Move Wireless Headphones are wireless over the ear headphones with an adjustable band.
The Jabra Move features a clean and simple Scandinavian design and their colors are inspired by the color palette of a modern metropolis. With a lightweight and firm over the ear design, the Jabra Move Headphones are suitable for working out. The adjustable headband is coated with dirt-resistant mesh, allowing breathability and padding to allow the headphones to remain lightweight. There is some flexibility to the headband which is a surprise feature.
The right earcup houses the power switch that is also used for Bluetooth discovery. Around the same place is the microUSB port for charging. Then on the left earcup, there is a 3.5mm input towards the bottom for wired listening for instances when the battery runs out. This earcup also houses the primary controls with the multifunction button, which covers the play and pause functions, voice control, and several basic phone controls. The volume rocker also works as a navigation to skip and backtrack to previous songs, with a longer hold of each button.
Technical Specifications
  • Box Contents:
    • 3.5 mm rubber cable
    • rubber USB cable
  • Weight:
    • 5.50 oz
    • 150g
  • Bluetooth:
    • Version: 4.0
    • Talking range: up to 10 m
    • Supported Profiles: Headset Profile v1.2 , Handsfree Profile v1.6, A2DP v1.2, AVRCP v1.4
  • Battery & Power:
    • Talk Time: Up to 8 hours
    • Standby Time: Up to 12 hours
  • Paired Devices: Up to 8 - connected to 2 at the same time (multiuse™)
  • Charging Time: Approximately 2 hours (dedicated charger)
  • Dimensions: main unit: H 172 x W 146,1 x D 59 mm (6.77 x 5.75 x 2.87 in)
  • Cable length: 3.5mm audio cable: 120 cm / USB charging cable: 100 cm
  • Speakers:
    • Size: 40mm dynamic speaker
    • Sensitivity: 94dBSPL with 60mV at 1kHz
    • Impedance: 29 Ohm ±15%
    • Max Input Power: 80mW
    • Frequency Range: 20Hz to 20kHz
  • Microphone:
    • Type: 4mm omni-directional microphone
    • Frequency Range: 100Hz to 8kHz TIA920
    • Sensitivity: SLR = 8dB ± 2dB TIA810/TIA920
  • Operating Temperature: -10° C to 60° C (14 F to 140 F)
  • Storage Temperature: -20° C to 85° C (-4 F to 185 F)
  • AC power supply: N/A
  • Charging plug dimensions: 5 PIN micro USB / B Type/W 8.03 x L 5.8 x H 3.04 mm (W 0.32 x L 0.23 x H 0.12 in)
  • Jabra Move Wireless materials: Silicon, PC, PU, ABS, TPE, Stainless Steel
  • Pairing passkey or PIN: 0000
  • Features: Automatic pairing mode, Answer call, end call, reject call, voice dialling, last number redial*, volume control, track control, Play/pause music
  • Certification: Bluetooth 4.0, CE, FCC, IC, GOST, RoHS, REACH
  • Warranty: One year limited warranty
Additional Information
Product Page
Amazon Product Page
Evan Noronha
crwdns2935283:002/05/15crwdne2935283:0
230,351 crwdns2915208:0crwdne2915208:0
crwdns2935297:0166crwdne2935297:0
crwdns2936753:030crwdne2936753:0 61
crwdns2959996:0crwdne2959996:0 7,915
