crwdns2933315:04crwdne2933315:0 crwdns2934263:07crwdne2934263:0 |
Motherboard cpu socket broken pins |
crwdns2933313:01crwdne2933313:0 crwdns2934263:00crwdne2934263:0 |
I have a I7 8700 and it dosn't work can it be fixed? |
crwdns2933315:06crwdne2933315:0 crwdns2934263:00crwdne2934263:0 |
socket 1366 pin missing |
Motherboard restarting at logo screen |
Background and Identification
The LGA 1366, also called the Socket B or Socket 1366, is an Intel CPU socket. As the name suggests, it has 1366 pins. Like socket 775, it is an LGA (land grid array) socket, meaning that the pins are on the motherboard and not the processor. The 1366 protruding pins touch contact points on the underside of the processor (CPU) and access up to three channels of DDR3 memory through the processor’s internal memory controller.
The Socket 1366 uses Intel’s QuickPath Interconnect (QPI) to connect the CPU to a reduced-function northbridge while a slower Direct Media Interface (DMI) connects the northbridge and southbridge components. Differences in pin numbers in Intel processors are mostly a reflection of the number of memory channels the processor can serve.
Intel’s Core i7 (released in 2008) was the first processor requiring the Socket 1366. The LGA 1366 socket and processors were discontinued in early 2012 and were succeeded by the LGA 2011 socket, which was released in November 2011 and supports Sandy Bridge E-series processors.
Intel’s X58 (desktop), 4300, 3420, 3450, 5500, 5520, and 7500 (server) chipsets support LGA 1366. Socket 1366 processors have mechanical maximum load limits of 890 Newtons (dynamic) and 266 Newtons (static) which should not be exceeded during heatsink assembly, shipping conditions, or standard use.
Technical Specifications
- Type: LGA
- Chip form factors: Flip-chip land grid array
- Contacts: 1366
- FSB protocol: Intel QuickPath Interconnect
- FSB frequency: 1× to 2× QuickPath
- Processor dimensions: 45 mm x 42.5 mm
- Processors:
- Intel Core i7 (9xx series)
- Intel Xeon (35xx, 36xx, 55xx, 56xx series)
- Predecessor:
- LGA 775 (high-end desktops and low-end servers)
- LGA 771 (low- and mid-end servers)
- Successor:
- LGA 2011 (desktops, low- and mid-end servers)
- LGA 1356 (low-end, dual-processor servers)
- Memory support: DDR3
