CVVT Oil Control Valve
crwdns2933315:02crwdne2933315:0 crwdns2934263:00crwdne2934263:0 |
No sound from radio |
crwdns2933313:01crwdne2933313:0 crwdns2934263:02crwdne2934263:0 |
My Hyundai accent 2010 model has use more fuel and no power |
P0730 Gear ratio incorrect (pulley) |
crwdns2933315:02crwdne2933315:0 crwdns2934263:01crwdne2934263:0 |
Rpm is not istable.it is up and down specialy if the ac is working |
crwdns2935065:0crwdne2935065:0
Checking Cables and Wires
- Check the terminal for tightness.
- Check terminals and wires for corrosion from battery electrolyte, etc.
- Check terminals and wires for open circuits.
- Check wire insulation and coating for damage, cracks, and degrading.
- Check the conductive parts of terminals for contact with other metallic parts (vehicle body and other parts).
- Check grounded parts to verify that there is complete continuity between their attaching bolt(s) and the vehicle''s body.
- Check for incorrect wiring.
- Check that the wiring is so clamped to the prevent contact with sharp corners of the vehicle body, etc. or hot parts (exhaust manifold, etc.)
- Check that the wiring is clamped firmly to provide enough clearance from the fan pulley, fan belt and other rotating or moving parts.
- Check that the wiring has a little space so that it can vibrate between fixed and moving parts such as the vehicle body and the engine.
