crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2935069:02crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
TF291203AJ
Background
The Husky Air Compressor TF291203AJ is a portable air compressor designed to power pneumatic tools and inflate tires. Manufactured by Husky Tools, it is primarily intended for home and shop use. The air compressor's specifications include a power source of 2.0 HP, a tank capacity of 2.6 gallons, and an air delivery of 2.4 CFM at 90 PSI. It has a maximum pressure of 135 PSI. This corded electric unit operates at a voltage of 120V and requires an amperage of 15A. The compressor features an oil-free pump and weighs approximately 29 lbs.
The TF291203AJ air compressor comes with features that include a 2.0 HP oil-free electric motor to provide power for quick recovery time. Its 2.6-gallon tank stores compressed air, allowing for extended runtimes for air tools. The model also includes a quick connect coupler for easy connectivity when inflating tires or powering air tools. It has a portable and lightweight design, complete with a carry handle for easy transport. Rubber feet are included to prevent movement during operation. A pressure regulator equipped with a gauge enables users to preset cut-out pressure within a range of 80 to 135 PSI. Additionally, manual thermal overload protection is included to prevent overheating. The Husky TF291203AJ air compressor is designed for a variety of applications, including inflating tires, powering small pneumatic tools like nail guns, brad nailers, staplers, die grinders, and airbrushes. It can supply an intermittent 2.4 CFM at 90 PSI, enabling the operation of one air tool at a time. The oil-free pump requires no maintenance.
Technical Specifications
  • Model Number: TF291203AJ
  • Product Type: Air Compressor
  • Manufacturer: Husky Tools
  • Power: 2.0 HP
  • Tank Capacity: 2.6 gallon
  • Air Delivery: 2.4 CFM @ 90 PSI
  • Maximum Pressure: 135 PSI
  • Power Source: Corded Electric
  • Voltage: 120V
  • Amperage: 15A
  • Pump Type: Oil-free
  • Weight: 29 lbs
Warranty
The Husky Air Compressor TF291203AJ is backed by a 2-year limited warranty. This warranty covers any defects in materials and workmanship that may occur under normal usage within this period. To claim the warranty, proof of purchase is necessary which helps in validating the time frame of the warranty. However, it is important to note that the warranty only applies to typical residential applications and does not cover commercial or industrial usage. Any such usage will void the warranty. Additionally, consumable parts like filters are not included in the warranty. In the event of any faults or issues, contact the manufacturer with your proof of purchase to initiate the warranty claim process.
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2942667:0crwdne2942667:0 289
