Back Wheel
crwdns2933313:01crwdne2933313:0 crwdns2934263:04crwdne2934263:0 |
My problem is electric scooter is not charging |
crwdns2933313:01crwdne2933313:0 crwdns2934263:00crwdne2934263:0 |
Handlebars misalign after turn |
Battery does not keep its charge drive maybe 15 feet then shuts off |
crwdns2933315:07crwdne2933315:0 crwdns2934263:02crwdne2934263:0 |
Need replacement handlebars and throttle |
crwdns2935065:0crwdne2935065:0
Troubleshooting
For additional help with the Hover-1 Eagle, check out the device's troubleshooting page.
Background
The Hover-1 Eagle Scooter is an electric scooter that was released in 2019. With the lightweight chassis of 20 pounds and collapsible handlebar, the Hover-1 Eagle was designed with portability in mind.
This electric scooter tops out at 15 miles per hour with a 7 mile distance range per charge. The handlebars house an electronic throttle, a LED speedometer, and a LED headlight. The handlebar also internally houses the battery pack with a 4Ah capacity. The base of the electric scooter is where both 6.5 inch wheels are mounted to, and where the braking pad is placed.
Hover-1 has released similar models to the Eagle, but this model can be easily identified by its large blue cross on the deck.
Identification
Identified by model number: Hover-1EGAL
Specifications
- Dimensions: 15.75 in x 45.75 in x 37.50 in
- Weight: 20.88 lbs
- Battery Capacity: 36V, 4.0 Ah, with overcharge and discharge protection
- Weight Capacity: 264 lbs
- Wheel Diameter: 6.5 in
- Miscellaneous: Front Wheel Drive, LED headlight, Electronic throttle and foot brake, App connectivity with learning modes, 5-hour max charge time
