crwdns2935067:01crwdne2935067:0
crwdns2933307:0crwdne2933307:0
RY803001
Background
The Ryobi RY803001 is a gasoline-powered pressure washer with a Honda GCV160 engine. The pressure washer produces 3000 pounds per square inch (PSI) of force. This model features a 5-in-1 change-over nozzle for various applications. The pressure washer includes an onboard detergent tank for easier soap application and uses cold water. The Ryobi RY803001 model uses 2.3 gallons per minute (GPM).
The Ryobi RY803001 model features a compact frame design and 12-inch flat-free wheels. It includes a 35-foot high-pressure hose. The pressure washer includes an air-cooled four-stroke overhead-camshaft Honda GCV160 engine. The engine produces a net power output of 4.4-horsepower at 3600 revolutions per minute. It can hold up to 0.58 US quarts of 86 octane or higher fuel and 0.98 US quarts (0.93 liters) of oil.
Identification
The Ryobi RY803001 can be identified by the name “Ryobi” printed in white capital letters on a plastic piece positioned between the pressure washer’s ‘U’-shaped handle. The words ‘3000 PSI’ and ‘3.2 GPM’ are printed underneath the Ryobi name on the plastic piece. The name “Honda” is printed in white capital letters on a black background on the front face of the machine’s bright green engine cover. Its quick-release handle can be detached from the pressure washer’s main body for more compact storage.
Technical Specifications
Dimensions:
  • Assembled Depth (in.): 21 in
  • Assembled Height (in.): 23.5 in
  • Assembled Width (in.): 21 in
  • Hose length (in.): 420
  • Interior Hose Diameter (In.): .25 in
  • Wheel Diameter (in.): 12 in
Details:
  • Assembly Required: Yes
  • CA (CARB) Compliant: CARB Compliant
  • Commercial / Residential: Residential
  • Connection Type: M22 Universal Threaded Twist On Hose & Trigger Handle
  • Engine Displacement (cc): 160
  • Engine Make: Honda
  • Engine Type: 4 Cycle Vertical
  • Features: Chemical/detergent injection, cold water
  • Fuel Tank Capacity (gallons): .25
  • GPM: 2.3
  • Hose Material: Plastic
  • Included: Detergent tank, wheels
  • Maximum Pressure (PSI): 3000
  • Nozzle Type: Adjustable
  • Number of tips included: 5
  • Pressure Washer Power Type: Gas
  • Product Weight (lb.): 56lb
  • Pump Brand: Other
  • Pump Type: Axial
  • Start Type: Recoil Start
  • Suggested Use: Decking, Driveway, Paint Preparation, Patio Furniture, Siding, Window
  • Water capability: Cold
Additional Information
Arielle Sampson
crwdns2935283:007/05/20crwdne2935283:0
17,131 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 139
crwdns2959996:0crwdne2959996:0 3,471
