crwdns2934263:03crwdne2934263:0
crwdns2933315:011crwdne2933315:0
crwdns2934263:02crwdne2934263:0
crwdns2934263:01crwdne2934263:0
crwdns2934263:04crwdne2934263:0
High Resolution Surround Sound
For the ultimate surround sound experience, the AVR-391 features a wide array of high resolution audio decoders, including Dolby TrueHD and DTS-HD Master Audio, as well as Dolby Pro Logic IIx, which provides Music, Cinema and Game modes.
HDMI 1.4a Includes 3D Blu-ray Compatibility
Equipped with 4 HDMI inputs, the AVR-391 includes the latest HDMI 1.4a specification, with support for 3D pass-through (Broadcast and Blu-ray).
Quality Discrete Power Amplifier Section
The equal power amp design features 5 matched discrete power amp circuits, and each channel is rated at 75 watts (8 ohms, 20 Hz to 20 kHz, .08% THD).
3.5mm Front Panel Audio Input Jack
To fully enjoy your favorite portable audio tracks, the AVR-391 features a convenient 3.5mm stereo audio jack on the front panel, allowing quick and easy connection to your portable audio device. And, the AVR-391 features Denon’s exclusive Compressed Audio Restorer function, which completely re-constructs the full audio frequency range, restoring lost high frequency detail for the most natural and believable tonal balance. (One-year warranty for Refurbished model)
GENERAL
Power Output; Watts Per Channel 75
All Channels Rated @ 0.08 THD
Weight (In Pounds) 20.3
Width (inches) 17.1
Height (inches) 6.7
Depth (inches) 15
SOUND MODES
dts-HD Master Audio and dts-HD High Resolution
Dolby Pro Logic IIx – with Cinema, Music, Game Modes
Dolby TrueHD and Dolby Digital+ Decoding
Dolby Digital Surround EX Decoding
dts ES Discrete 6.1 Decoding
dts ES Matrix 6.1 Decoding
dts Neo:6 Stereo-to-Surround Cinema and Music Mode
dts 96/24 5.1 for DVD-Video Processing
Audio Signal Delay (Sync. Audio with Video signal) – By source
5-Channel Stereo Mode
Virtual Surround Mode – For 2 Speakers/Headphones
Multi-Channel Stereo Mode
DSP Effect Modes - 2
Active Center Channel In All Surround Modes
CONNECTIVITY
True 24-bit/96-kHz Digital Input Capability
Assignable Digital Inputs - 2
Digital Inputs: Coaxial - 1
Digital Inputs: Optical - 1
Analog Audio Inputs, Incl. Tuner - 5
HDMI 1.4a Inputs with Full 3D Pass Through - 4
Composite Video Inputs - 3 Incl. Front
Composite Video Outputs - 1
S-Video Inputs - 1 x Dock
HDMI 1.4a Outputs with Audio Return Channel Support - 1- No Audio Return Channel Support
Banana Plug Speaker Terminals, All Channels - Front L/R only
56 Station Auto-Preset Memory Tuning
Direct Function (Tone Bypass)
Volume Control Un-muting
Selectable Muting Levels (Full/-40/-20)
Video Select Control - Not for use with HDMI Sources
Speaker Time-Delay and Level Controls: L/R, Sub, C, Surr. L/R, Surround Back
Pre-Amp Outputs - Surround Back L, Surround Back R, Sub
iPod Dock Control Port (Using optional Denon Docks) - ASD-11R/ASD-51N/ASD-51W
Pre Labled Assignable Digital Inputs
HDMI 1.3a Inputs - 4 x 1.4a
HDMI 1.3a Outputs - 1 x 1.4a
HDMI Audio/Video Repeater Function
HDMI Deep Color Support-36Bit
HDMI xvYCC Color Space Support
COMPONENT TECHNOLOGY
Equal Power Amplifiers Y/5 Ch
Low Impedance Drive Capability
High-Current/Discrete Amplifiers
Independent Power Supplies
24-bit/192-kHz DACs - AKM Semiconductor - Cirrus 24-bit/192-kHz CS42528
Analog-to-Digital Conversion - Bit Depth/Sampling Rate - 24-bit/96-kHz
Variable High/Low Pass Crossover Points (12/24dB) 40 / 60 / 80 / 100 / 120 / 150 / 200 / 250
CONVENIENCE FEATURES'''
Front Panel System Setup Control
Personal Memory Plus
Microprocessor User Re-set Y
Nephew
crwdns2935283:011/11/13crwdne2935283:0
49 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
crwdns2936753:030crwdne2936753:0 65
crwdns2959996:0crwdne2959996:0 15,012
