Controller
crwdns2933315:02crwdne2933315:0 crwdns2934263:05crwdne2934263:0 |
My hard disk not working |
Background and Identification
The Hitachi GST Deskstar model HDS721010CLA332 is an internal desktop hard drive. The Deskstar line is a series of desktop-class hard drives in a 3.5-inch form factor with SATA interfaces. The Deskstar series was announced by IBM in October 1994 and was continued by Hitachi in 2003 when Hitachi purchased IBM’s hard drive disk division. Hitachi (also called HGST, or Hitachi Global Storage Technologies) manufactured hard disk drives, solid-state drives, and external storage products and services between 2003 and 2018. In 2012, the hard drive disk division was sold to Western Digital, who continued the Deskstar product line as HGST Deskstar. The Deskstar HDS721010CLA332 model (also called the Deskstar 7K1000.B) was manufactured by Hitachi.
The Deskstar HDS721010CLA332 model features between 160GB and one terabyte of digital internal storage and 7200 RPM performance. It is designed for consumer and commercial applications, including personal storage and PC gaming. Hitachi advertises that this disk drive uses up to 18-percent less power than previous-generation disk drives. The manufacturer also advertises a 13-percent faster media transfer rate over the disk drive’s predecessor. The 7K1000.B disk drive features ‘Advanced Power Management’ which reduces power during idle periods. It also includes between 16GB and 32GB of cache buffer.
Technical Specifications
General:
- Features: Temperature sensor, load/unload technology, Hitachi Voltage Efficiency Regulator Technology (HiVERT), Thermal Flyheight Control (TFC), S.M.A.R.T.
- Interface: SATA 3Gb/s
- Buffer Size: 32 MB
- Weight: 23.98 oz
- Manufacturer: Western Digital Corp.
Miscellaneous:
- Microsoft Certifications: Compatible with Windows 7
Interface Provided:
- Qty: 1
- Connector Type: 7 pin Serial ATA
- Storage Interface: Serial ATA-300
- Interface: Serial ATA-300
Expansion and Connectivity:
- Interfaces: 1 x SATA 3 Gb/s - 7 pin Serial ATA
Hard Drive:
- Form Factor: 3.5" x 1/3H
- Interface Type: Serial ATA-300
- Spindle Speed: 7200 rpm
- Features: Hitachi Voltage Efficiency Regulator Technology (HiVERT), Thermal Flyheight Control (TFC), load/unload technology, temperature sensor
- Hard Drive Type: internal hard drive
- Form Factor (Short): 3.5"
- Form Factor (metric): 8.9 cm x 1/3H
- Form Factor (Short) (metric): 8.9 cm
- Data Transfer Rate: 300 MBps
- Internal Data Rate: 198 MBps
- Non-Recoverable Errors: 1 per 10^14
- Start / Stop Cycles: 300000
Performance:
- Drive Transfer Rate: 300 MBps (external)
Environmental Standards:
- ENERGY STAR Certified: Yes
Environmental Parameters:
- Min Operating Temperature: 32 °F
- Max Operating Temperature: 140 °F
- Humidity Range Operating: 8 - 90%
Storage Hard Drive:
- Compliant Standards: S.M.A.R.T.
Header:
- Brand: WD
- Product Line: HGST Deskstar 7K1000.C
- Model: HDS721010CLA332
- Compatibility: PC
Dimensions and Weight:
- Width: 4 in
- Depth: 5.8 in
- Height: 1 in
- Weight: 23.98 oz
Bay Required:
- Type: internal
Reliability:
- Start / Stop Cycles: 300,000
General:
Additional Information
- Hitachi GST Deskstar Hard Drive Data Sheet
- Hitachi GST Deskstar HDS721010CLA332 Hard Drive Specifications
- Hitachi GST Deskstar HDS721010CLA332 Hard Drive on Amazon
- Hitachi GST Deskstar HDS721010CLA332 Hard Drive Review
- Hitachi GST Deskstar HDS721010CLA332 Hard Drive Best Price
Hitachi Deskstar 7K1000.C 3.5-Inch Hard Drives (160GB to 1TB) Data Sheet
