crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0crwdns2935091:0crwdnd2935091:0crwdne2935091:0
Background
The HP Pavilion x360 15-dq0065cl is a touch screen laptop developed by HP Inc in June of 2019. The laptop has a special feature that allows it to convert into a tablet using the 360 degree hinge attached to the keyboard. It runs on Windows 10 and is part of the 8th generation of laptops. The HP Pavilion x360 15-dq0065cl was only ever produced in a silver color classified as "natural silver" although most companies only classified the color as silver. The display resolution is 1366 x 768 pixels with an aspect ratio of 16:9.
The product would later be proceeded by the ENVY x360 series and shortly after updated with a new generation processor.
Identification
Other than its base line color of silver the HP Pavilion x360 15-dq0065cl can be identified when its full name is broken down.
- The name Pavilion is the name of this particular line of laptops.
- The x360 defines that the laptop can convert to become a tablet due to the laptop sporting a 360 degree hinge.
- The number 15 in the name represents the size of the laptop being 15 inches.
- The dq shows all the models with the same chassis.
- 0065 represents the configuration of the laptop.
- The cl suffix usually represents where the laptop was sold. In this case the cl is most commonly used to identify Costco.
The HP Pavilion x360 15-dq0065cl has 360 degree hinge that can be seen connecting the tablet and the keyboard. The laptop is touch screen. The dimensions are 14.1 inches in width, 9.5 inches in depth, and 0.8 inches in height. The laptop weighs 4.2 lbs. The keyboard is standard and black with a touchpad.
The HP Pavilion x360 15-dq0065cl has multiple ports on its left and right side.
- Right Side: Charging port, HDMI port, USB type-c port (only used for data transport at the time), and a SD card reader port.
- Left Side: 2 USB type-A ports, headphone/microphone jack, and a Kensington lock slot.
The HP Pavilion x360 15-dq0065cl model number can be underneath the laptop near the 360 hinge.
Technical Specifications
Screen
Display: 15.6
Display Resolution: 1366 x 768 pixels
Aspect Ratio: 16:9
Touch Screen
Pannel Type: SVA
Processor
Processor: Intel Core i7-8565U
Processor Generation: 8th gen
Processor Frequencies: 1.8GHz-4.6GHZ
Processor Cores: 4
Processor Cache: 8 MB
Memory
Internal Memory: 12 GB
Internal Memory Type: DDR4-SDRAM
Memory Clock Speed: 2400 MHZ
Storage
Storage Media: SSD
Total Storage Capacity: 512GB
SSD Capacity: 512GB
1 installed SSD
SD Comapatible Memory Card
SSD Interface: NVMe,PCI Express
Graphics
Does have an On-Board Graphics Card
Does not have a Discrete Graphics Card
On-Board Graphics Card Model: Intel UHD Graphics 620
Audio
Audio System: B&O Play
Speakers: 2
Includes a built in microphone
Camera
Front Facing HD Camera
Camera Type: HP Wide Vision HD
Network
Bluetooth Compatible
Bluetooth Version: 4.2
Top Wi-Fi Standard: Wi-Fi 5 (802.11ac)
Ports
2 USB Type-A ports
1 USB Type-C port
1 HDMI port
1 Headphone/Mic port
1 Charging Port
Charging Port Type: DC-in jack
Software
OS: Windows 10 Home
Pre-Installed: Dropbox, Netflix
Trial: McAfee LiveSafe
Operating System Architecture: 64-bit
Battery
Capacity: 41 Wh
Battery Cells: 3
Battery Type: Lithium-Ion
Max Battery Life: 10.25 Hours
Weight and Dimensions
Weight: 4.2 lbs
Width: 14.1 inches
Depth: 9.5 inches
Height: 0.8 inches
Sources: Kelaptop and NotebookCheck
