305DX, 337NR, 337WM, 387WM
Background:
The HP 15 Notebook PC is an economical laptop part of HP's 15-inch consumer laptop portfolio. It was built primarily for students, casual users, and professionals who required an economical yet functional computer for daily computing work.
This series features a range of model numbers with minor hardware configuration differences, including f305dx, f200c, f387wm, f337nr, f337wm, and f3387wm. The laptop features a 15.6-inch display with HD (1366x768) resolution and is powered by various AMD or Intel CPUs, depending on the version.
Additional typical features included 500GB to 1TB hard drives, 4GB to 8GB of RAM, and integrated graphics solutions like AMD Radeon R4/R5 or Intel HD Graphics, making it appropriate for light gaming, document processing, online browsing, and media streaming.
Identification:
  1. The HP Notebook 15 series has a sleek, modern appearance with a lightweight but robust plastic or aluminum frame, depending on the model.
  2. The HP 15 Notebook PC has a screen size of 15.6 inches. It features a 16:9 ultra-wide aspect ratio white light-emitting diode (WLED) display.
  3. The laptop is 38.56 cm (15.18 in) in width, 25.8 cm (10.15 in) in depth, and 2.26 cm (0.89 in) in thickness.
  4. The laptop weighs between 2.09 kg (4.61 lb) and 2.29 kg (5.05 lb), depending on the setup.
  5. The service tag at the bottom of the laptop has the model number.
  6. The laptop comes in a single color—black.
  7. The HP logo, a white display bezel, and a textured island-style keyboard are important visual indicators.
Technical Specifications:
Processors:
  • AMD A6-5200 (2.0 GHz, 2 MB L2, 1600MHz DDR3L), quad core, 15 W
  • AMD E1-6010 (1.35 GHz, 1 MB L2, 1333MHz DDR3L), dual core, 10 W
  • AMD E1-2100 (1.0 GHz, 1 MB L2, 1333MHz DDR3L), dual core, 9 W
  • AMD A8-6410 (2.0 GHz, 2 MB L2, 1600MHz DDR3L), quad core, 15 W
  • AMD A4-5000 (1.5 GHz, 2 MB L2, 1600MHz DDR3L), quad core, 15 W
  • AMD E1-3000 (1.65 GHz, 1 MB L2, 1600MHz DDR3L), dual core, 15 W
Chipset:
AMD Integrated SOC FCH
Internal Graphics:
  • AMD Radeon R5 Graphics (A8 processors)
  • AMD RadeonT HD 8400 (A6-5200 processors)
  • AMD Radeon HD 8330 (A4-5000 processors)
  • AMD Radeon HD 8280 (E2-3000 processors)
  • AMD Radeon HD 8210 (E1-2100 processors)
Memory:
  • Two SODIMM customer-accessible/upgradable memory module slots
  • DDR3L-1600-MHz dual channel support
  • DDR3L-1333-MHz single channel support (DDR3L-1600 downgraded to DDR3L-1333)(E1 processors)
  • Supports up to 8 GB max system memory (DDR3L-1600MHz module) (select models only)
RAM Configurations:
  • 8192 MB (8192 MB×1)
  • 6144 MB (4096 MB×1 + 2048 MB×1)
  • 4096 MB (4096 MB×1 or 2048 MB×2)
  • 2048 MB (2048 MB×1)
Hard drives:
  • 750 GB, 5400 rpm, 9.5 mm
  • 500 GB, 5400 rpm, 9.5 mm and 7.0 mm
  • 320 GB, 5400 rpm, 9.5 mm and 7.0 mm
Additional Information
  1. Troubleshooting - HP Support
  2. Security and Viruses - HP Support
  3. Tools and Diagnostics - HP Support
  4. Pavilion PCs made easy
  5. Common Problems
Jeff Stephens
crwdns2935283:002/21/11crwdne2935283:0
278.365 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Staff
crwdns2935297:072.713crwdne2935297:0
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 1,465
