crwdns2935069:02crwdne2935069:0
crwdns2933307:0crwdne2933307:0
HDPXPCO, Mini-Rooter XP
Background and Identification
The General Pipe Cleaners Drain Cleaner, also called the Mini-Rooter XP, is an auto-feed drain cleaning machine that is manufactured by General Pipe Cleaners, which is a division of the American family-owned company General Wire Spring Co.
This drain cleaner is capable of cleaning drains between 2 and 4 inches in diameter. It has an maximum extension length of 50 feet, and the cable is 1/2 of an inch in diameter. It features a power cable feed, which can extend and return cable to the machine at a rate of 20 feet per minute. The cleaner has several safety features, including a cable guide that means the user does not need to touch the rotating cable as the machine auto-feeds into the drain, which could cause injury. It also has thermal overload protection, which helps to keep the engine from overheating and damaging the machine. This auto-feed drain cleaner can be used for both commercial and home use. On average, an auto-feed drain cleaner can be set up and used in under 10 minutes. Gloves are required when operating this drain cleaner both for safety and hygiene.
Technical Specifications
  • Cable length: 50 ft
  • Cable Diameter: 1/2 in
  • Assembled Depth: 36 in
  • Assembled Height: 21 in
  • Assembled Width: 19 in
  • Weight: 112 lbs
  • Engine horsepower:1/3 HP
Additional Information
Home Depot Rental
Operating Manual
Mini Rooter XP Product Page
Electric Drain Cleaners - Wikipedia
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 179
crwdns2936753:030crwdne2936753:0 751
crwdns2959996:0crwdne2959996:0 19,472
