crwdns2935069:013crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
EDR-260
Background
The Echo Engine Drill EDR-260 is a gas-fueled drill produced by Echo Power Equipment and is constructed for heavy-duty drilling tasks. The drill is powered by a 260cc engine and it's designed to manage substantial drilling jobs that require high torque. The drill is equipped with a 260cc 2-stroke engine. It utilizes a mix of gasoline and oil as fuel. The maximum drilling diameter is 2 inches (50 mm) in wood and 5/8 inch (16 mm) in metal. The drill weighs 15.4 lb (7.0 kg) and measures 15.6 inches (40 cm) in length.
The EDR-260 features an adjustable D-style handle and vibration-reducing grips for comfort during prolonged use. It also includes a large fuel tank for extended runtimes between refueling and a 2-stage air filter to reduce dust intake and maintain consistent power. The drill also uses a decompression valve starter system for smooth starts and a centrifugal clutch to prevent twist-back if the bit gets stuck. Regular maintenance for the drill includes changing the spark plug and air filter, as well as cleaning the exterior.
Technical Specifications
  • Engine: 260cc 2-stroke engine
  • Power output: 2.7 HP
  • Fuel: Gasoline/oil mix
  • Fuel tank capacity: 21.8 fl oz (0.65 L)
  • Max drilling diameter (wood): 2 inches (50 mm)
  • Max drilling diameter (metal): 5/8 inch (16 mm)
  • Drill chuck size: 3/4 inch (19 mm)
  • Weight: 15.4 lb (7.0 kg)
  • Length: 15.6 inches (40 cm)
Warranty
The Echo Engine Drill EDR-260 comes with a warranty coverage of 5 years for consumers and 2 years for commercial use. The specifics of the warranty coverage are not explicitly stated in the document, but typically, such warranties cover manufacturing defects and faults originating from normal usage of the product. To claim the warranty, one would likely need to contact Echo's at-home service as indicated in the document. However, for precise details about what the warranty covers and the process of claiming it, it would be best to consult the official Echo website or the product's user manual.
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 58
crwdns2942667:0crwdne2942667:0 1,215
