crwdns2935069:017crwdne2935069:0
crwdns2933307:0crwdne2933307:0
PE-2620
Background
The Echo Edger PE-2620 is a lawn edger powered by gasoline. It is intended for domestic use, primarily for defining edges along driveways, walkways, and flower beds.
The Echo Edger PE-2620 is equipped with a 2-stroke, 21.2 cc engine and a fuel tank with a capacity of 0.53 L. The engine operates on a 50:1 gasoline to oil ratio. The standard equipment includes a straight steel edging blade, with the option of adding different types of edger blades for ornamental edging. Weighing 8.8 lbs, the edger is relatively lightweight, facilitating ease of handling. Additional features include rubber-padded handles for operator comfort, and the option to install the assist handle on either side for left or right-handed operation. The edger operates by pulling the recoil starter handle, with the engine speed controlled by a throttle trigger on the assist handle. It operates at a maximum of 7,800 rpm. Regular maintenance, such as cleaning or replacing the air filter and replacing the spark plug periodically, is necessary for optimal engine performance.
Technical Specifications
  • Engine Type: 2-stroke
  • Engine Displacement: 21.2 cc
  • Max RPM: 8,800
  • Fuel Tank Capacity: 0.53 L
  • Fuel Type: 50:1 gasoline/oil mixture
  • Weight: 8.8 lbs
  • Handle Type: Rubber padded handles
  • Operation: Can be used with either left or right hand
  • Blade Type: Straight steel blade (optional decorative blades available)
  • Starting Mechanism: Recoil starter handle
  • Speed Control: Throttle trigger on the assist handle
Warranty
The Echo Edger PE-2620 is backed by a 5-year consumer warranty, applicable for non-commercial use. This warranty covers any defects in the material or workmanship of the product. However, it's important to note that the warranty does not extend its coverage to damage caused by misuse, abuse, or improper maintenance. In order to claim the warranty, the original purchaser must provide proof of purchase. This policy is limited to the original purchaser only.
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2959996:0crwdne2959996:0 486
