crwdns2935069:04crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
DXPW4035
Background & Identification
The Dewalt DXPW4035 4000 PSI 3.5 GPM Gas Powered Cold Water Pressure Washer is a heavy duty pressure washer with high PSI and above-average flow rate, powered by a small yet powerful Honda GX270, and accompanied by a AAA Triplex Plunger Pump for maximum performance, even in challenging environments. The unit is small enough to be easily maneuverable, even in tight corridors, and features an all-metal frame, rubber vibration dampening feet, and large heavy-duty “mud type” tires for easy rolling on the most inhospitable terrain.
The unit comes equipped with a tray to hold the five included gun tips (Dewalt 4500 PSI Quick-Connect Spray Tips (DXPA45ST)), including a soap tip and soap adapter, a Dewalt 4500 PSI Spray Gun (DXPA45SG), a Dewalt 4500 PSI 31” Spray Wand Extension (DXPA31SW), and a Dewalt 3/8 in. x 50 ft. 5000 PSI Extension Hose (DXPA50PH). The unit includes holders for the hose and gun, features a low oil automatic shutoff, and implements 1/4” quick connects for fast tip changes and ease of use. While this model has been discontinued, it can still be purchased used from various sources, or new from Home Depot.
This pressure washer can be identified by the black, silver, and yellow color scheme, the black text “Dewalt” an a yellow background on the tip holder of the back handle, the front bumper, the side of the spray gun, and the air filter. Additionally, the model can be identified by the text “4000 PSI” and “3.5 GPM” on the air filter of the engine, on the pullcord side of the machine.
Technical Specifications
Hose Diameter: 3/8”
Hose Length: 600” (15.2m)
Quick Connect Size: 1/4”
Wand Length: 31” (78.7 cm)
Max Pressure: 4000 PSI
Minimum Pressure: 3500 PSI
Spray Tip Sizes: 0 Degrees, 15 Degrees, 25 Degrees, 40 Degrees
Engine: Honda GX270
Oil Capacity: 1.16 U.S. quarts (1.1 L)
Fuel Tank Capacity: 1.4 U.S. gallons (5.3 liters)
Fuel: Unleaded 86 octane or higher
Net Power Output: 8.5 HP (6.3 kW) @ 3,600 rpm
Net Torque: 14.1 lb-ft (19.1 Nm) @ 2,500 rpm
Dry Weight: 126 lb (57.2 kg)
Assembled Height: 26” (66 cm)
Assembled Depth: 28” (71 cm)
Assembled Width: 24.25” (61.59 cm)
Wheel Diameter: 13” (33 cm)
Additional Information
Dewalt 4000 PSI 3.5 GPM Gas Pressure Washer at Home Depot
Dewalt 4000 PSI 3.5 GPM Gas Pressure Washer Owner’s Manual
Dewalt 4500 PSI 31” Spray Wand Extension/Replacement (DXPA31SW)
Dewalt 3/8 in. x 50 ft. 5000 PSI Extension/Replacement Hose (DXPA50PH)
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 68
crwdns2959996:0crwdne2959996:0 2,109
