crwdns2935067:01crwdne2935067:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
D28116
Background
The D28116 is a heavy-duty, small angle grinder first released in 2007, with an update around 2016. It is designed for professionals in masonry and metal work, The D28116 was marketed as a high-power Small Angle Grinder (SAG) for heavy-duty metal removal and concrete cutting. It was one of the first in its class to feature the Dust Ejection System, which uses centrifugal force to eject debris out of the tool before it reaches the motor. While DeWalt doesn't disclose total numbers of units sold, the D28116 was widely available in both North American and European markets and is a mainstay on shelves at big box hardware stores that still have an excess of units.
The D28116 has no manufacturer recalls but is prone to common issues such as switch failure, carbon brush wear, power cord fatigue, and flange nut seizing. The D28116 has received universal praise for its power-to-weight and size ratio, but many consumers complain about heat build-up in the gearbox with extended use. The unit retailed for 120-150 USD and can be found refurbished for around the same price today. The D28116 replaced the D28114 as the high-output option in the 28000-series, offering a higher amperage motor and improved debris management. It was eventually succeeded by the DWE402, which featured a more streamlined body and redesigned "Dust Ejection System 2.0."
Identification
  • The Nameplate: Locate the black and yellow sticker on the side of the motor housing. It must clearly list the model as D28116 and the type as Type 1.
  • Date Code: For the 2016 version, look for a 10-digit code (e.g., 2016-XX-XX) stamped into the plastic housing near the cord or on the nameplate.
  • Physical Features: This specific model features a Trigger Grip (rather than a paddle switch) and a distinctive low-profile "jam-pot" gear case designed for access to tight spaces.
Specifications
  • Motor: 13.0 Amp / 2.3 HP (AC/DC).
  • Speed: 9,000 RPM (Note: Some 5" models vary, but the D28116 standard is 9,000 RPM).
  • Weight: 8 lbs.
  • Length: 19.75 inches.
  • Safety Features: Includes an adjustable keyless guard and a vibration-reducing side handle.
  • Internal Parts: Uses high-purity graphite/copper blend carbon brushes
Additional Information
DeWalt Angle Grinder D28116 - TYPE 1 (2016) on Amazon
Official manual
How to use your angle grinder
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 295
