crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2935067:01crwdne2935067:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
D28115
Background
Dewalt Angle Grinder D28115 - TYPE 2 (2016) is a high performance angle grinder. It is used to deliver industrial-grade power in compact form. The type 2 version came out in 2016 and the design is only different internally.
There are no major differences from earlier version externally. The big difference between type 1 and 2 is there are safer measures and faster and better motor components.
Its primary use is metal cutting and grinding, removing rust and paint, and construction work. The compact design and low-profile head make it ideal for tight spaces and it has a dust ejection system. It also has a 13 amp motor and high torque and speed (9000 rpm).
Identification
To find the correct device check the nameplate / rating label on the side or bottom of the grinders motor. It will provide the brand model number and type. It has yellow/black housing with molded vents. Also to double check if you got the right model the manual will have the model and type on the front.
Technical Specifications
  • Motor: 13.0 amp
  • Speed: 9000 RPM
  • Weight: 4.2 lb
  • Width: 18 in
  • Spindle Thread: 5/8-11 (corded)
  • Dust Ejection System
  • Source: DeWalt Contractor supply
Additional Information
Contractor Supply
Syndigo pdf
Tool Source
DeWalt Official Page
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 234
