crwdns2934263:03crwdne2934263:0
crwdns2934263:01crwdne2934263:0
Mavic Remote Controller
Background and Identification
The DJI Mavic is a series of quadcopter drones for commercial and personal aerial videography and photography use. The DJI Mavic Remote Controller is sold with DJI’s Mavic Pro drones and is used to control the aircraft and gimbal wirelessly. The controller is compatible with DJI’s line of Mavic Pro drones, including the Mavic 2 Pro and Mavic 2 Zoom, which were released by DJI in August 2018, and the original Mavic Pro, which was released in 2016.
The Mavic remote controller can be used to control the Mavic Pro quadcopter and gimbal from up to 4.3 miles away. It can also be used in Dual Remote Controller Mode to fly and capture photos and videos with a second pilot. A second remote controller can also be used for teaching, as both ‘Master’ and ‘Slave’ remote controllers can control the gimbal and aircraft. The ‘Master’ remote controller can be used to override a less experienced pilot using the ‘Slave’ controller. A Micro-USB OTG cable is required when using this remote controller for the Mavic Mini.
The Mavic remote controller features an LCD (liquid crystal display) screen that displays aircraft data. Mobile devices like tablets and smartphones can be mounted in the controller’s adjustable handles so users can view the DJI application while in flight. It also includes Lighting, Micro-USB, and USB-C connectivity options. The controller has two antennae that can fold to be flush with the body of the remote for better storage. The remote controller’s body is a dark gray color and it includes one joystick on either side of the LCD screen (two joysticks total).
Technical Specifications
Remote Controller:
  • Operating Frequency: 2.400 - 2.483 GHz; 5.725 - 5.850 GHz
  • Max Transmission Distance:
    • 2.400 - 2.483 GHz; 5.725 - 5.850 GHz
    • FCC: 10000 m
    • CE: 6000 m
    • SRRC: 6000 m
    • MIC: 6000 m
  • Operating Temperature Range: 0℃ - 40℃
  • Transmission Power (EIRP):
    • 2.400 - 2.483 GHz
    • FCC: ≤26 dBm
    • CE: ≤20 dBm
    • SRRC: ≤20 dBm
    • MIC: ≤20 dBm
      • 5.725-5.850 GHz
    • FCC: ≤26 dBm
    • CE: ≤14 dBm
    • SRRC: ≤26 dBm
  • Battery: 3950 mAh
  • Operating Current/Voltage: 1800 mA ⎓ 3.83 V
  • Supported Mobile Device Size: Max length: 160 mm; max thickness: 6.5–8.5 mm
  • Supported USB Port Types: Lightning, Micro USB (Type-B), USB-C
Additional Information
Jeff Stephens
crwdns2935283:002/21/11crwdne2935283:0
277.539 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Staff
crwdns2935297:072.303crwdne2935297:0
crwdns2936753:030crwdne2936753:0 104
crwdns2942667:0crwdne2942667:0 12,105
