crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2935067:01crwdne2935067:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
917.3886
Background
The Craftsman Walk Behind Mower model 917.388600, manufactured by the Roper Corporation for Sears, is a lawn mower specifically designed for residential use. With a 20-inch cutting width and an adjustable cutting height between 1-3 inches, it is equipped to handle a variety of lawn conditions. The mower operates on a 4.25 horsepower Craftsman 143.024202 4-cycle engine, which is started via a recoil mechanism. The machine uses a 20-inch steel blade and discharges clippings from the rear. It is manually moved with the aid of 7-inch plastic wheels.
For upkeep, the owner's manual recommends checking the engine oil before each use, and changing it after the first 5-8 hours of operation, then every 25 hours or at the change of the season. The air filter should be inspected or replaced every 25 hours or at the start of a new season, while the spark plug should be replaced and blade sharpened annually or after every 100 hours of use. The manual also includes instructions for lubrication, cleaning and other routine maintenance procedures.
Technical Specifications
  • Engine: Craftsman 143.024202 4-cycle engine, 4.25 HP
  • Cutting width: 20 in
  • Cutting height: 1-3 in, adjustable
  • Blade: 20 in steel blade
  • Starter: Recoil
  • Transmission: Manual push
  • Wheels: 7 in plastic wheels
Warranty
The Craftsman Walk Behind Mower model 917.388600 comes with a limited one-year warranty provided through Sears. This warranty covers any defects in material or workmanship for one year from the date of purchase. The engine is also covered under the warranty for a year, given the condition that the mower is properly maintained as per the guidelines provided in the manual. However, the warranty does not extend to normal wear items such as blades, belts, and air filters. It should be noted that for commercial or rental use, the warranty coverage is limited to only 90 days from the date of purchase.
Craftsman 917.388600 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2942667:0crwdne2942667:0 356
