crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2935067:01crwdne2935067:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
917.38835
Background
The Craftsman Walk Behind Mower 917.388350 is a lawn maintenance tool produced by Roper Corp for Sears. It is a rotary lawn mower with a 21-inch cutting width. The mower is equipped with a 6.25 hp engine. The mower offers the capability of multi-cut, providing options for mulching, rear bagging, or side discharge of grass clippings. It also features a 9-position height adjustment, allowing for a range of 1-1/2 to 4 inches, catering to various lawn maintenance needs. The mower weighs around 60 lbs.
In terms of operation, the mower is started by adding oil and gas, moving the choke lever to the choke position, holding the operator presence bar down to the handle, and pulling the starter rope. When the engine starts, the choke lever is moved to the run position. The cutting height can be adjusted by moving the height adjustment levers on each wheel. For mulching, the rear door and mulcher door need to be closed. For rear bagging, the grass catcher needs to be installed and the mulcher door closed. For side discharge, the rear door needs to be closed, the mulcher door opened, and the discharge deflector installed. Regular maintenance checks and cleaning are recommended for optimal performance.
Technical Specifications
  • Model Number: 917.388350
  • Engine: 6.25 hp
  • Cutting Width: 21 inches
  • Mowing Options: Mulching, Rear Bagging or Side Discharge
  • Height Adjustment: 9 position height adjustment from 1-1/2 to 4 inches
  • Weight: 60 lbs
Warranty
The Craftsman Walk Behind Mower 917.388350 carries a limited two-year warranty. This warranty covers any defects in materials and workmanship, provided the mower has been maintained in accordance with the operating and maintenance instructions. However, the warranty does not extend to expendable parts such as blades, belts, and air filters. It also doesn't cover damage resulting from improper use and neglect of maintenance. The warranty is considered void if the mower is used for commercial purposes or rented out. To claim the warranty, refer to the guidelines outlined in the product's manual or contact the manufacturer directly.
Craftsman 917.388350 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2942667:0crwdne2942667:0 303
