crwdns2935069:02crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
917.37701
Background
The Craftsman Walk Behind Lawn Mower 917.377010 is a gas-powered, self-propelled rotary lawn mower produced by Roper Corporation for Sears. The machine is equipped with a 675 Series Briggs & Stratton engine with a displacement of 163cc. It uses unleaded regular gasoline, with a fuel capacity of 1.6 quarts. The mower has variable speed front wheel drive and features a cutting width of 21 inches with a cutting height that can be adjusted between 1 to 3.75 inches in 7 increments. The mower also has the ability to mulch, side discharge, or rear discharge with additional hardware.
The Craftsman 917.377010 lawn mower has a steel mowing deck and is capable of adjusting to 6 different heights between 1 to 3.75 inches using a dual point system. The mower operates on a 163cc Briggs & Stratton 675 Series engine with automatic choke, simplifying the starting process as it requires no priming or choking. The engine speed is preset and is not adjustable by the user. The mower is designed with several user-replaceable parts, such as the air filter, spark plug, blade, and wheels, supporting the potential for DIY maintenance and repairs.
Technical Specifications
  • Model Number: 917.377010
  • Product Type: Walk Behind Mower
  • Engine: 675 Series Briggs & Stratton engine, 126T02-0709-EA
  • Displacement: 163cc
  • Fuel Type: Unleaded regular gasoline, minimum 87 octane
  • Fuel Capacity: 1.6 quarts
  • Oil Capacity: 20 ounces
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Drive Type: Variable speed front wheel drive
  • Cutting Width: 21 inches
  • Cutting Height: 1-3.75 inches in 7 adjustments
  • Wheel Size: 9 x 2.25 inches front and rear
  • Mulching Capability: Yes with mulching plug
  • Rear Bagging Capability: Yes with grass catcher
  • Side Discharge Capability: Yes with side discharge chute
  • Weight: 60 lbs
Warranty
The Craftsman Walk Behind Lawn Mower 917.377010 comes with a 2-year full warranty that covers any defects in materials or workmanship. For commercial use, parts and labor are covered for the first 90 days. However, it's important to note that the warranty does not extend to normal wear items or any damage caused by improper use or lack of maintenance. To claim the warranty, it is likely necessary to provide proof of purchase and contact the manufacturer, although the exact procedure is not specified in the provided document.
Craftsman 917.377010 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2959996:0crwdne2959996:0 495
