crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2935069:02crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
917.37663
Background
The Craftsman Walk Behind Mower 917.376630 is a gas-powered lawn mower produced by Sears. It operates using a self-propulsion mechanism and is powered by a 7.0 horsepower Briggs & Stratton 128602-0445-E1 engine. The fuel capacity of this mower is 1.6 quarts of unleaded regular gasoline. It also has an oil capacity of 20 ounces and uses API SG-SL type oil. The mower has a 22-inch steel blade and comes equipped with 7-position height-adjustable wheels. The weight, width, length, and height of the mower are approximately 150 lbs, 22 inches, 51 inches, and 40 inches respectively.
The Craftsman 917.376630 is equipped with a Briggs & Stratton engine and possesses a recoil start. It has a primer bulb to facilitate easy cold starting. The engine speed is fixed and cannot be adjusted by the user. The mower is capable of mulching, bagging, or side discharging grass clippings. It features a rust-resistant steel deck and 10-inch rear wheels. The rear bagging system can be installed without the use of tools and the mower also has an optional side discharge chute. The self-propulsion system is variable in speed and is controlled by a bail lever. The mower's speed can be adjusted using a turnbuckle found on the underside.
Technical Specifications
  • Model Number: 917.376630
  • Product Type: Walk Behind Mower
  • Engine: 7.0 horsepower Briggs & Stratton 128602-0445-E1
  • Fuel Capacity: 1.6 quarts unleaded regular gasoline
  • Oil Capacity: 20 ounces SAE 30 (above 32°F); SAE 5W-30 (below 32°F)
  • Oil Type: API SG-SL
  • Blade: 22 inch steel
  • Blade Bolt Torque: 35-40 ft-lbs
  • Wheels: 7-position height adjustment
  • Weight: Approx. 150 lbs
  • Width: 22 inches
  • Length: 51 inches
  • Height: 40 inches
Warranty
The Craftsman Walk Behind Mower 917.376630 comes with a limited 2-year warranty. This warranty covers defects in materials and workmanship for non-commercial use. However, it's important to note that the warranty does not include coverage for normal wear items like belts, blades, and brake pads. In addition, any issues stemming from improper use or lack of maintenance are not covered by the warranty. The engine warranty is a separate matter and is covered independently by Briggs & Stratton.
Craftsman 917.376630 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2942667:0crwdne2942667:0 334
