crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2935069:02crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
917.376523
Background
The Craftsman Walk Behind Mower 917.376523 is a gas-powered lawn mower that was manufactured by Roper Corp for Sears. This walk behind mower is powered by a 6.5 horsepower Briggs & Stratton engine, model 123K02-0447-E1, which uses unleaded gasoline as fuel. The mower has a cutting width of 21 inches, and the cutting height is adjustable between 1 and 3.5 inches.
The mower is self-propelled with a variable speed rear-wheel drive. It starts with a recoil start mechanism. It also features a rear bagging and mulching capability. The mower weighs approximately 60 lbs. It has a folding handle function which allows for compact storage. The mower requires regular maintenance such as changing engine oil, cleaning under the deck, replacing or sharpening the blade when needed, and periodic cleaning of the air filter and spark plug.
Technical Specifications
  • Model Number: 917.376523
  • Product Type: Walk Behind Mower
  • Manufacturer: Sears
  • Engine: 6.5 horsepower Briggs & Stratton, model 123K02-0447-E1
  • Cutting Width: 21 inches
  • Cutting Height: Adjustable, 1-3.5 inches
  • Drive Type: Self-propelled, variable speed rear-wheel drive
  • Start Type: Recoil start
  • Fuel Type: Unleaded gasoline
  • Fuel Capacity: 1.6 quarts
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 20 ounces
  • Weight: Approximately 60 lbs
  • Additional Features: Steel cutting deck, 9 position height adjustment, rear bagging and mulching capability, easy pull recoil start, folding handle for compact storage.
Warranty
The Craftsman Walk Behind Mower 917.376523 comes with a limited warranty which lasts for two years. This warranty covers any defects in the materials and workmanship of the product, as long as it is used for non-commercial purposes. However, it is important to note that normal wear items such as belts, blades, and air filters are not covered under this warranty. In addition, the engine warranty is covered separately by Briggs & Stratton. If you encounter any issues with your mower that you believe are covered under the warranty, refer to your warranty card or owner's manual for instructions on how to claim it.
Craftsman 917.376523 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2959996:0crwdne2959996:0 467
