crwdns2935069:02crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
917.376393
Background
The Craftsman Walk Behind Mower 917.376393 is a lawn mower with a 22-inch multi-cut deck, designed for residential lawn care. It is equipped with a Briggs & Stratton 126T02-1346-B1 engine with a displacement of 163 cc and a power output of 6.75 ft-lbs gross torque. This walk-behind mower has a fuel capacity of 1.6 quarts and an oil capacity of 20 oz. It uses SAE 30 oil type above 32°F and SAE 5W-30 below 32°F. The mower utilizes a Champion RJ19HX spark plug with a gap of .030".
The mower has an operator presence control bar and six adjustable cutting heights. It has the ability to mulch, rear bag, and side discharge. The mower's mobility is facilitated by its 7-inch front wheels and 8-inch rear wheels. It also features a folding T-shaped handle for better handling and storage. The deck size is 22" and the cutting height is adjustable from 1-3/4" to 4". The mower weighs 66 lbs. The mower operates with an automatic choke and the engine speed is not user adjustable. The operator presence control bar must be held down to start and run the mower. Routine maintenance includes checking engine oil before each use, cleaning under the mower deck, replacing the air filter annually, replacing the blade when worn, and changing the engine oil every 25 hours of use.
Technical Specifications
  • Model Number: 917.376393
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 126T02-1346-B1
  • Displacement: 163 cc
  • Power: 6.75 ft-lbs gross torque
  • Fuel Capacity: 1.6 quarts
  • Oil Capacity: 20 oz
  • Oil Type: SAE 30 (above 32°F); SAE 5W-30 (below 32°F)
  • Spark Plug: Champion RJ19HX (gap: .030")
  • Blade Bolt Torque: 35-40 ft-lbs
  • Deck Size: 22" multi-cut
  • Cutting Height: 1-3/4" to 4" adjustable
  • Weight: 66 lbs
  • Other Features: Operator presence control bar, Adjustable cutting height (6 positions), Mulching, rear bagging, and side discharge capabilities, 7 inch front wheels, 8 inch rear wheels, Folding T-shaped handle
Warranty
The Craftsman Walk Behind Mower 917.376393 comes with a 2-year full warranty which covers any manufacturer defects in material or workmanship. However, note that the warranty period is reduced to 90 days if the mower is used commercially. It should be noted that the warranty does not cover parts that are subject to normal wear and tear, or damage caused by improper use or lack of maintenance.
Craftsman 917.376393 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2942667:0crwdne2942667:0 261
