crwdns2935069:02crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
917.37623
Background
The Craftsman Walk Behind Mower Model 917.376230 is a self-propelled lawn mower. It is designed with a 21" cutting width and a Briggs & Stratton 127cc engine that offers 5.5 ft-lbs of torque. The mower employs a recoil starting mechanism. It features a steel mower deck, which allows for the adjustment of the cutting height from 1" to 3.75" through a 9 position height adjustment lever. The machine utilizes a 22" steel blade for cutting grass and has the capability to mulch, bag, or side discharge grass clippings.
The front wheels of the mower measure 7" and the rear wheels are 8" in diameter. The operation of the mower is facilitated by a variable speed front wheel drive, which can be controlled via the operator presence control bar. The wheels are designed with ball bearings to ensure smooth operation. The mower also includes features like an easy access oil fill and drain, and adjustable handle height. The mower weighs 88 lbs and requires unleaded regular gasoline with a minimum octane rating of 87. The fuel capacity is 1.6 quarts, while the oil capacity stands at 20 oz. The mower can operate in temperatures above 32°F with SAE 30 oil and below 32°F with SAE 5W-30 oil.
Technical Specifications
  • Model Number: 917.376230
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 124T02-1227-EA 127cc engine
  • Power: 5.5 ft-lbs gross torque
  • Fuel Type: Unleaded regular gasoline, minimum 87 octane
  • Fuel Capacity: 1.6 quarts
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 20 oz
  • Blade: 22" steel blade
  • Cutting Width: 21"
  • Cutting Height: 1-3.75" (9 position adjustment)
  • Drive Type: Variable speed front wheel drive
  • Starting: Recoil start
  • Deck Material: Steel
  • Wheels: 7" front, 8" rear
  • Weight: 88 lbs
Warranty
The Craftsman Walk Behind Mower Model 917.376230 comes with a full warranty that lasts for 2 years from the purchase date. This warranty covers any defects in both material and workmanship, offering repair or replacement of the product free of charge. To claim the warranty, customers should bring the mower to a Sears retail outlet. However, it's important to note that routine maintenance items such as oil, filters, blades, and brake pads are not included in the warranty coverage. Furthermore, any damage resulting from improper use or abuse of the mower is also excluded from the warranty.
Craftsman 917.376230 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 442
