crwdns2935069:02crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
917.376152
Background
The Craftsman Walk Behind Mower 917.376152 is a gasoline-operated lawn mower. It has a 6.75 horsepower Briggs & Stratton 125K02-0658-E1 4-cycle engine. The mower features a 22-inch cutting width and an adjustable cutting height from 1 to 3.5 inches in six increments. It also includes a self-propelled, variable speed rear-wheel drive system. The mower has three mowing functions: rear bagging, mulching, and side discharge, and weighs about 66 lbs.
This mower comes equipped with a Briggs & Stratton 125K02-0658-E1 engine, a 4-stroke overhead valve with a displacement of 163 cc. It uses unleaded gasoline and has a fuel capacity of 1.6 quarts. The oil type it uses is SAE 30 or SAE 5W-30, and the oil capacity is 20 ounces. The mower uses a Champion RJ19LM or J19LM spark plug with a gap of 0.030 inches. The mower also features a blade brake clutch system which stops the blade while allowing the engine to run when the operator releases the engine zone control bar. It also includes a primer bulb for starting a cold engine.
Technical Specifications
  • Manufacturer: Sears, Roebuck and Co.
  • Power source: 6.75 horsepower Briggs & Stratton 125K02-0658-E1 4-cycle engine
  • Cutting width: 22 inches
  • Cutting height: Adjustable from 1-3.5 inches in 6 increments
  • Drive type: Self-propelled, variable speed rear-wheel drive
  • Mowing functions: Rear bagging, mulching, and side discharge
  • Weight: 66 lbs
  • Engine Model: Briggs & Stratton 125K02-0658-E1
  • Engine type: 4-stroke overhead valve
  • Displacement: 163 cc
  • Fuel type: Unleaded gasoline
  • Fuel capacity: 1.6 quarts
  • Oil type: SAE 30 or SAE 5W-30
  • Oil capacity: 20 ounces
  • Spark plug: Champion RJ19LM or J19LM
  • Ground Speed: up to approximately 3.5 mph
  • Cutting Deck: 22 inch steel cutting deck with multiple blades
  • Adjustable cutting height: between 1 and 3.5 inches in 6 preset increments
Warranty
The Craftsman Walk Behind Mower 917.376152 comes with a 2-year full warranty, provided by Sears, which covers all manufacturer defects in materials and workmanship. However, it's worth noting that if the mower is used for commercial purposes, the warranty period is reduced to 90 days. If you need to claim the warranty, you should contact Sears directly, providing details of the defect and proof of purchase to validate your claim.
Craftsman 917.376152 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 43
crwdns2959996:0crwdne2959996:0 557
