crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2935069:05crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
917.37581
Background
The Craftsman Walk Behind Mower 917.375810 is a lawn mower that is self-propelled and uses gas. It was made by Husqvarna specifically for Sears. The mower uses a 6.75 hp Briggs & Stratton 125K02-0654-E1 engine and runs on 1.6 quarts of regular unleaded gasoline. The mower requires 20 oz. of SAE 30 or SAE 5W-30 oil, depending on the temperature. The cutting width of the mower is 22 inches, and the cutting height can be adjusted to between 1 and 4 inches. The mower weighs approximately 70 lbs.
The Craftsman Walk Behind Mower has a 22 inch steel cutting deck that can be used for mulching, rear bagging, or side discharging grass clippings. The mower's rear wheel drive system uses a variable speed V-belt and can be engaged by pulling the drive control lever located on the upper handle. The drive speed can be adjusted using the turnbuckle on the underside of the drive control housing. The mower is equipped with a float feed carburetor and recoil pull start. The mower's engine speed is set at the factory and is not adjustable by the user. The spark plug should be replaced at the beginning of each mowing season or after every 100 hours of use.
Technical Specifications
  • Model Number: 917.375810
  • Product Type: Walk Behind Mower
  • Engine: 6.75 hp Briggs & Stratton 125K02-0654-E1
  • Fuel Capacity: 1.6 quarts unleaded regular gasoline
  • Oil Capacity: 20 oz. SAE 30 (above 32°F); SAE 5W-30 (below 32°F)
  • Cutting Width: 22 in.
  • Cutting Height: 1-4 in. (9 position adjustment)
  • Operating Modes: Mulching, Rear Bagging or Side Discharge
  • Starting System: Electric start capable
  • Weight: approx 70 lbs
Warranty
The Craftsman Walk Behind Mower 917.375810 comes with a 2-year limited warranty provided by Husqvarna for non-commercial use. The warranty covers any manufacturing defects or issues encountered under normal usage conditions within this period. Additionally, the engine of the mower has a separate warranty that is covered by Briggs & Stratton. To claim the warranty, customers should contact the respective manufacturers, Husqvarna for the mower and Briggs & Stratton for the engine, and provide the necessary details, which may include proof of purchase, model number, and description of the issue.
Craftsman 917.375810 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 247
