crwdns2935069:06crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
917.37455
Background
The Craftsman Walk Behind Mower 917.374550 is a self-propelled lawn mower produced by Sears Brands LLC. It is equipped with a Briggs & Stratton 128T05-1268-B1 engine that delivers a power rating of 6.75 ft-lbs gross torque. The mower features an electric start with a recoil backup, a variable speed rear wheel drive, and an adjustable handle with three different height positions. It also has a 22-inch-wide cutting deck that offers seven different cutting height positions ranging from 1 to 4 inches.
The mower includes a 2.3-bushel capacity fabric grass catcher for rear bagging and allows for side discharge mowing. Its fuel capacity is 1.6 quarts of regular unleaded gasoline. The engine also comes with a dual element air filter to ensure clean air supply. It has 11-inch rear wheels and 8-inch front wheels, and it weighs in at 66 lbs. The speed and power of the mower can be adjusted to suit different mowing conditions.
Technical Specifications
  • Engine Model: Briggs & Stratton 128T05-1268-B1
  • Engine Displacement: 163 cc
  • Engine Power: 6.75 ft-lbs gross torque
  • Fuel Capacity: 1.6 quarts unleaded regular gasoline
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 20 oz
  • Blade Type: 22" steel deck blade
  • Cutting Width: 22 inches
  • Cutting Height: 1-4 inches adjustable
  • Starter Type: Electric start with recoil backup
  • Transmission: Variable speed rear wheel drive
  • Weight: 66 lbs
  • Cutting Deck Width: 22 inches
  • Cutting Height Range: 1-4 inches adjustable
  • Grass Catcher Capacity: 2.3 bushel
  • Rear Wheel Size: 11"
  • Front Wheel Size: 8"
  • Drive Control: Lever on upper handle
  • Handle Height Positions: Three adjustables
Warranty
The Craftsman Walk Behind Mower 917.374550 comes with a 2 year full warranty from the date of purchase, covering defects in material or workmanship. This warranty offers repair or replacement if repair is not possible. However, it is essential to note that the warranty does not cover normal wear and tear items such as belts, blades, or filters. For engine-related issues, Briggs & Stratton separately cover the warranty. To claim the warranty, you should have your date of purchase recorded, and in case of any defect, you should contact the retailer or the manufacturer with this information.
Craftsman 917.374550 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2959996:0crwdne2959996:0 841
