crwdns2935069:06crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
917.374544
Background
The Craftsman Walk Behind Mower 917.374544 is a self-propelled, gas-powered lawn mower made by the Sears Brands Management Corporation. This rotary mower has a 22-inch cutting width and offers 7 adjustable cutting height positions, ranging from 1-1/2 inches to 4 inches.
The mower uses a Briggs & Stratton 128T02-1270-B1 127cc OHV engine with a fuel capacity of 1.6 quarts for regular unleaded gasoline. The oil type varies with the temperature; SAE 30 is used above 32°F while SAE 5W-30 is used below 32°F. The mower has a self-propelled, variable speed rear wheel drive and a geared transmission. The body of the mower is made from steel, and it weighs 95 lbs in total. Other important features of this product include a recoil starter, blade speed of up to 3250 rpm, a 2 bushel fabric grass catcher, and optional side discharge with mulch plug. For easy cleaning, it also has a water washout fitting.
Technical Specifications
  • Engine: Briggs & Stratton 128T02-1270-B1 127cc OHV
  • Displacement: 127cc
  • Fuel capacity: 1.6 quarts unleaded regular gasoline
  • Oil type: SAE 30 above 32°F; SAE 5W-30 below 32°F
  • Oil capacity: 20 oz
  • Drive type: Self-propelled, variable speed rear wheel drive
  • Transmission: Geared
  • Deck material: Steel
  • Cutting width: 22 inches
  • Cutting height: 7 positions, 1-1/2" to 4" adjustable
  • Starter: Recoil
  • Blade speed: Up to 3250 rpm
  • Rear bagger: 2 bushel fabric grass catcher included
  • Side discharge: Optional with mulch plug
  • Mulching: Standard with mulch plug
  • Deck wash: Water washout fitting
  • Tires: 11" rear, 8" front
  • Weight: 95 lbs
Warranty
The Craftsman Walk Behind Mower 917.374544 comes with a 2-year full warranty. This warranty covers any defects in materials and workmanship from the date of purchase. If repair or replacement is needed due to these defects, it will be covered under this warranty. However, the warranty does not extend to normal wear items such as belts, blades, or filters, nor does it cover issues that arise from improper maintenance, modifications, misuse, or abuse. The engine warranty is separately provided by Briggs & Stratton.
Craftsman 917.374544 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 28
crwdns2959996:0crwdne2959996:0 853
