crwdns2935069:06crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
917.37435, 917.374350
Background
The Craftsman Walk Behind Mower 917.374350 is a self-propelled, gas-powered lawn mower. It is equipped with a 127cc Briggs & Stratton engine, and it has a power rating of 3.75 horsepower. The mower features a 22-inch steel mowing deck, and a 7-position height adjustment that allows for a cutting height range of 1 to 3.75 inches. It is designed to operate either as a mulcher or with a rear bag for grass collection. The mower also has 7 inch front wheels and 8 inch rear wheels, with the rear wheels being power-driven and having variable speed control.
Additionally, the Craftsman 917.374350 has a fuel capacity of 1.6 quarts and uses unleaded gasoline. It uses SAE 30 oil when the temperature is above 32°F, and SAE 5W-30 oil when the temperature is below 32°F. The oil capacity is 20 ounces. The blade bolt torque is 35-40 ft-lbs and the spark plug type is Champion RJ19HX with a gap of 0.030". The mower deck is made of steel and the blade is 22 inches long, which can be removed without tools for cleaning and replacement.
Technical Specifications
  • Engine: Briggs & Stratton 128T02-1270-B1 127cc
  • Power rating: 3.75 hp
  • Cutting width: 22 inches
  • Cutting height: 1-3.75 inches (7 positions)
  • Mulching and rear bagging capabilities: Yes
  • Wheels: 7 inch front wheels, 8 inch rear wheels
  • Weight: 140 lbs
  • Fuel type: Unleaded gasoline
  • Fuel capacity: 1.6 quarts
  • Oil type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil capacity: 20 oz
  • Blade bolt torque: 35-40 ft-lbs
  • Spark plug: Champion RJ19HX (gap: 0.030")
Warranty
The Craftsman Walk Behind Mower 917.374350 comes with a 2-year full warranty that covers defects in materials and workmanship. However, it's important to note that this warranty only applies to residential use. If the mower is used for commercial purposes, the warranty coverage is reduced to 90 days. The warranty does not cover routine maintenance items such as oil, filter, blades, and belts. Furthermore, damage that occurs due to improper use or abuse of the product is not covered under the warranty. To claim the warranty, it's often necessary to provide proof of purchase or another form of verification to confirm the product's validity and the timeframe in which it was purchased.
Craftsman 917.374350 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2959996:0crwdne2959996:0 306
