crwdns2935067:01crwdne2935067:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
917.37179
Background
The Craftsman Walk Behind Mower 917.371790 is a gas-powered lawn mower manufactured by Roper Corp for Sears. It is equipped with a 21" multi-cut steel mowing deck for extensive coverage of your lawn and a Briggs & Stratton 126L02-1080-F1 engine with a power rating of 4 HP. The engine contains a displacement of 10.5 cu. in. The mower has a fuel tank capacity of 1.6 quarts for unleaded regular gasoline and an oil capacity of 20 oz. It provides a cutting width of 21 inches and an adjustable cutting height between 1-3 inches. The mower has a manual push transmission and a wheel size of 7 inches in the front and 8 inches in the rear.
This mower includes several features such as an operator presence control bar, mulching, rear bagging or side discharge capabilities, and a 9 position height adjustment lever. It also has a folding handle that allows for compact storage. For maintenance, it is recommended to check the engine oil before each use and to change it after every 25 hours of operation. Other maintenance tasks include cleaning the air filter every 25 hours, replacing it annually, changing the oil filter annually, replacing the spark plug annually, sharpening or replacing the mower blade annually, and clearing debris buildup under the mower deck after each use.
Technical Specifications
  • Model Number: 917.371790
  • Product Type: Gas-powered walk behind lawn mower
  • Engine: Briggs & Stratton 126L02-1080-F1
  • Displacement: 10.5 cu. in.
  • Power: 4 HP
  • Fuel Tank Capacity: 1.6 quarts of unleaded regular gasoline
  • Oil Capacity: 20 oz SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Cutting Width: 21 inches
  • Cutting Height: Adjustable 1-3 inches
  • Deck Material: Multi-cut steel
  • Transmission Type: Manual push
  • Wheel Size: 7 inches front, 8 inches rear
  • Weight: 60 lbs
Warranty
The Craftsman Walk Behind Mower 917.371790 comes with a warranty coverage of 2 years for normal use, guaranteeing against any defects in materials and workmanship. However, this period is reduced to 90 days in case the mower is used for commercial or rental purposes. Notably, the warranty does not cover normal wear parts such as blades, belts, air filters, and spark plugs, and any maintenance or adjustments required for normal operation are also excluded. To claim the warranty, it is necessary to provide valid proof of purchase.
Craftsman 917.371790 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2942667:0crwdne2942667:0 294
