crwdns2935069:016crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
917.37095
Background
The Craftsman Walk Behind Mower 917.370950 is a lawn mower that operates on petrol. Crafted by Craftsman, this mower is equipped with a 190cc Honda GCV190 engine and a 22-inch steel blade. The cutting deck can be adjusted to seven different heights, ranging from 1 to 3.75 inches, using a single point height adjustment lever. The mower is capable of mulching, rear bagging, and side discharge. The mower is designed with a front wheel drive system, using a variable speed cable-driven transmission controlled by a bail bar.
The Craftsman Walk Behind Mower 917.370950 engine is a four-stroke overhead cam engine with a 0.95 quart fuel tank and an air filter for intake air cleaning. The engine operates on regular unleaded gasoline and requires 18.5 oz of oil for lubrication. The mower features an electric start button and a recoil starter for convenience. The mower's cutting deck is 22 inches, made of steel, and can perform multiple functions such as mulching, bagging or side discharging. The mower is designed with a front-wheel-drive system that uses a variable-speed cable-driven transmission engaged with a bail bar control. The speed can be adjusted by squeezing the drive control levers toward the handlebar. Regular maintenance of the mower includes checking the engine oil, replacing the air filter, and replacing spark plugs.
Technical Specifications
  • Model Number: 917.370950
  • Product Type: Walk Behind Mower
  • Engine: 190cc Honda GCV190 4-stroke overhead cam engine
  • Fuel tank capacity: 0.95 quart
  • Oil capacity: 18.5 oz
  • Start mechanism: Electric start button and a recoil starter
  • Cutting Width: 22 inches
  • Cutting Height: Adjustable from 1 to 3.75 inches in 7 positions
  • Discharge Capabilities: Mulching, rear bagging, and side discharging
  • Drive: Variable speed front wheel drive
  • Blade: 22 inch steel blade
  • Transmission: Cable driven, engaged with a bail bar control
  • Speed control: Adjusted by squeezing the drive control levers toward the handle bar.
Warranty
The Craftsman Walk Behind Mower 917.370950 comes with a 2-year full warranty. This warranty covers any defects in material and workmanship, ensuring that if any part of the product fails due to a manufacturing error within this period, it will be dealt with by the company. However, it's important to note that this warranty does not extend to consumable parts such as filters and spark plugs, or issues arising from improper maintenance. To claim the warranty, you should contact Craftsman directly, providing proof of purchase and details of the defect. Please remember to adhere to the recommended maintenance schedules and guidelines provided in the product manual to keep the warranty valid.
Craftsman 917.370950 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2959996:0crwdne2959996:0 745
