crwdns2935069:02crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
917.37089
Background
The Craftsman Walk Behind Mower 917.370890 is a lawn mower designed for outdoor use. It is a self-propelled, gas-powered device, manufactured by the Roper Corporation for Sears under the Craftsman brand. The machine is equipped with a Briggs & Stratton engine, which has a capacity of 163cc. The mower uses regular unleaded gasoline and has a fuel capacity of 1.6 quarts. The oil used can be SAE 30 or SAE 5W-30 depending on the temperature, with an oil capacity of 18 oz.
The mower has a 22" steel blade and the cutting height can be adjusted between 1-4 inches with nine different position adjusters. It also features a dual lever, variable speed rear-wheel drive for easy maneuverability. Other features include mulching, rear bagging, and side discharge capabilities, and an operator presence control bar. The machine also includes a water washout port for easier cleaning. The device weighs 150 lbs and is equipped with 7" front wheels and 8" rear wheels.
Technical Specifications
  • Engine: Briggs & Stratton 128M02-1612-F1 163cc
  • Fuel capacity: 1.6 quarts unleaded regular gasoline
  • Oil type and capacity: SAE 30 (above 32°F); SAE 5W-30 (below 32°F), 18 oz
  • Blade: 22" steel blade
  • Blade bolt torque: 35-40 ft-lbs
  • Spark plug: Champion RJ2YXLE, 0.020" gap
  • Cutting height: 1-4 inches, 9 position adjusters
  • Wheels: 7" front, 8" rear
  • Weight: 150 lbs
Warranty
The Craftsman Walk Behind Mower 917.370890 comes with a 2-year full warranty. This warranty covers any defects found in material and workmanship. However, it's important to note that it does not cover consumable parts, modifications, normal wear and tear, improper maintenance, or any form of abuse. To claim the warranty, you're advised to visit the Sears website where you can find the full details on coverage and instructions on how to proceed with your claim.
Craftsman 917.370890 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 37
crwdns2959996:0crwdne2959996:0 1,323
