crwdns2935069:02crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
917.370441
Background
The Craftsman Walk Behind Mower 917.370441 is a gas-powered lawn mower that is manufactured by Craftsman. The mower is powered by a Briggs & Stratton 128M05-5468-F1 engine with a power rating of 5.5 horsepower. This model has a cutting width of 22 inches and features a steel deck. The mower has a height adjustment feature with six different positions, ranging from 1-1/2 inches to 4 inches. It offers three different grass handling options: rear bag, side discharge, and mulch. The mower has a variable speed rear wheel drive and an electric start with a recoil backup.
The Briggs & Stratton 128M05-5468-F1 engine has a displacement of 163 cc and runs on unleaded gasoline with a fuel capacity of 1.6 quarts. The oil type used varies based on temperature: SAE 30 is recommended above 32°F, while SAE 5W-30 is recommended below 32°F. The oil capacity is 18 ounces. The Craftsman 917.370441 is primarily intended for residential yard maintenance. It requires regular maintenance, including checks of engine oil before each use, changes of engine oil and oil filters, inspections of air filters, replacement of spark plugs, and sharpening or replacement of the mower blade as needed. Cleaning under the mower deck after each use is also recommended to prevent buildup of grass clippings.
Technical Specifications
  • Engine Model: Briggs & Stratton 128M05-5468-F1
  • Engine Displacement: 163 cc
  • Engine Power Rating: 5.5 hp
  • Fuel Type: Unleaded gasoline
  • Fuel Capacity: 1.6 quarts
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 18 ounces
  • Cutting Width: 22 inches
  • Cutting Height: 1-1/2 to 4 inches in 6 adjustments
  • Starter Type: Recoil and electric start
  • Transmission Type: Variable speed rear wheel drive
  • Blade Size: 22" steel
  • Deck Material: Steel
Warranty
The Craftsman Walk Behind Mower 917.370441 is provided with a 2-year full warranty, which covers any defects that may arise due to materials or workmanship. However, it's important to note that routine wear items such as belts, blades, and filters are excluded from this coverage. Additionally, the warranty becomes void if the mower is utilized for commercial purposes or if it is not maintained appropriately. To claim the warranty, it is generally advisable to contact the manufacturer or the seller, providing proof of purchase and a detailed description of the issue. However, for specific claim procedures, it's recommended to refer to the warranty section in the product's owner manual or contact the manufacturer directly.
Craftsman 917.370441 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 1,130
