crwdns2935067:01crwdne2935067:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
247.38923
Background
The Craftsman Walk Behind Mower 247.38923 is a lawn mower designed for residential use. Produced by MTD for Sears under the Craftsman brand, this mower is powered by a 140cc Briggs & Stratton engine. It has a cutting width of 21 inches, and the cutting height can be adjusted between 1 and 3 inches. This mower can be used for either mulching or bagging grass clippings. The mower is self-propelled and features a recoil starter.
The Craftsman Walk Behind Mower 247.38923 incorporates several useful features. The mower has a foldable T-shaped handle with three adjustment settings, and an integrated blade control for easy starting. The mower also includes a rear bag with a capacity of 2.4 bushels for grass collection. It has a trail shield at the rear to deflect debris. The mower's weight is approximately 60 lbs. Regular maintenance is necessary for keeping the mower in good condition, including checking the engine oil level before each use, changing the engine oil as necessary, cleaning the deck, inspecting the blade, and lubricating necessary parts. The engine air filter and spark plug also need periodic replacement.
Technical Specifications
  • Model Number: 247.38923
  • Product Type: Walk Behind Mower
  • Engine: 140cc Briggs & Stratton
  • Engine Oil Type: SAE 30
  • Engine Oil Capacity: 18 oz
  • Fuel Type: Unleaded gasoline, minimum 87 octane
  • Cutting Width: 21 inches
  • Cutting Height: 1-3 inches adjustable
  • Capabilities: Mulching and rear bagging
  • Weight: 60 lbs
  • Deck Type: Steel, 21-inch
  • Starter Type: Recoil
  • Grass Catcher Bag Capacity: 2.4 bushel
  • Handle Type: Foldable T-shaped, with 3 adjustment settings
  • Safety Feature: Integrated blade control bail, rear trail shield
Warranty
The Craftsman Walk Behind Mower 247.38923 comes with a 2-year full warranty which covers any defects in materials and workmanship. Should you encounter any issues with the product, the warranty entitles you to a repair or replacement if the repair is not feasible. However, it's important to note that routine maintenance items such as oil, filters, blades, and spark plugs are exceptions to the warranty coverage. Additionally, the warranty becomes null and void if the mower is used for commercial purposes or is rented out to others.
Craftsman 247.38923 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 36
crwdns2959996:0crwdne2959996:0 372
