crwdns2935069:02crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
247.37
Background
The Craftsman 247.37000 is a walk-behind lawn mower designed for residential use. It is equipped with a 163 cc Briggs & Stratton engine and a 21-inch steel mower deck. Users have the option of mulching or side discharging the grass clippings. The height of the mower deck can be adjusted between 1 to 3 inches in six increments with dual levers, one by each wheel. This mower is started with a recoil rope and a primer bulb, and it features an engine kill switch that is activated by a blade control bail.
This lawn mower uses unleaded gasoline for fuel and SAE 30 oil. It has a weight of 55 lbs. and features 7-inch front wheels and 8-inch rear wheels. Regular maintenance is suggested, including checking the engine oil before each use, inspecting the blade and mounting hardware for damage, lubricating control cables and pivot points, cleaning the underside of the mower deck, changing the air filter annually or more frequently in dusty conditions, changing the spark plug annually, and before storage, draining the fuel or adding stabilizer to prevent gumming.
Technical Specifications
  • Engine: Briggs & Stratton 163 cc
  • Fuel type: Unleaded gasoline
  • Oil type: SAE 30
  • Oil capacity: 15 oz
  • Cutting width: 21 in
  • Cutting height: 1-3 in
  • Wheel size: 7 in front, 8 in rear
  • Weight: 55 lb
Warranty
The Craftsman Walk Behind Mower model 247.37000 comes with a 2 years limited warranty. This warranty covers defects in materials and workmanship that could potentially occur during the covered period. However, it's important to note that the warranty does not include expendable parts like belts, blades, and spark plugs which are subject to wear. To claim the warranty, one should refer to the owner's manual for detailed instructions. It's also recommended to keep the original purchase receipt as it might be required for warranty claims. Regular maintenance according to the provided owner's manual is advisable to ensure safe operation and maximize the mower's lifespan.
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2942667:0crwdne2942667:0 487
