crwdns2935069:013crwdne2935069:0
247.37705
Background
The Craftsman Walk Behind Mower 247.377050 is a gas-powered push lawn mower that is produced by Sears Brands. It is equipped with a Briggs & Stratton engine and uses SAE 30 engine oil. The mower operates using unleaded gasoline and has a cutting width of 21 inches. Users have the ability to adjust the cutting height between 1-3 inches. The mower weighs 60 lbs.
The Craftsman Walk Behind Mower 247.377050 has a steel cutting deck and the capability to discharge from the side and mulch. It also includes a 7 position height adjustment lever, folding cushioned handles, a rear bag for catching grass, and an easy pull recoil start. The mower must be regularly maintained for optimal performance. This includes checking the engine oil level before each use, cleaning the underside of the mower deck periodically, replacing the air filter and spark plug annually, and lubricating control linkages and wheels once a season. Craftsman lawn mowers have been produced by Sears Brands since the 1920s. The 247.377050 model was first introduced in 2015 for home use.
Technical Specifications
  • Model Number: 247.377050
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton
  • Engine Oil: SAE 30
  • Fuel Type: Unleaded Gasoline
  • Cutting Width: 21 Inches
  • Cutting Height: Adjustable, 1-3 Inches
  • Weight: 60 lbs
Warranty
The Craftsman Walk Behind Mower 247.377050 comes with a 2-year limited warranty. This warranty covers any defects in material or workmanship that may occur during this period. However, it's important to note that the warranty does not cover expendable parts such as blades, belts, and air filters. The engine warranty is distinct and is provided separately by the engine manufacturer. To claim the warranty, refer to the operator's manual for the detailed process or contact the manufacturer directly.
Craftsman 247.377050 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 1,359
