crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2935067:01crwdne2935067:0
crwdns2933307:0crwdne2933307:0
315.26921
Background
The Craftsman 315.269210 is a variable speed router, an electric tool designed to hollow out an area in hard materials such as wood or plastic. Manufactured by Diehl Mfg Co for Sears, it operates on 120V, 60Hz, AC only, 9.5A power supply. The tool is equipped with a 2 horsepower motor and uses 1/2 inch and 1/4 inch collet sizes. It has a no-load speed ranging between 15,000 to 25,000 RPM, which can be controlled via a 6-step dial. The depth of cut capacity of the router ranges between 0 to 1 1/2 inches. The router has a clear plastic base and a 10-feet long power cord. It weighs approximately 7 lbs 6 oz.
The Craftsman 315.269210 router has several features that enhance its functionality. These include a variable speed control dial for optimal speed selection depending on the material and bit size, a spindle lock for single wrench bit changes, and a depth adjusting ring with an indicator point for precise depth settings. Furthermore, it accepts both 1/2" and 1/4" collet sizes and has a vacuum attachment capability for dust collection. The router also includes a locking arm to secure the motor housing in the base and is durably constructed for reliability. It is used for routing edges, cutting joints, trimming laminates, and more.
Technical Specifications
  • Power: 120V, 60Hz, AC only, 9.5A
  • Motor: 2 horsepower
  • Collet Sizes: 1/2 inch and 1/4 inch
  • No Load Speed: 15,000-25,000 RPM variable speed
  • Speed Control: 6-step dial allows speed selection from 15,000 to 25,000 RPM
  • Depth of Cut Capacity: 0-1 1/2 inches
  • Base: Clear plastic chip shield installed, can attach vacuum for dust collection
  • Power Cord Length: 10 feet
  • Weight: 7 lbs 6 oz
Warranty
The Craftsman 315.269210 router is backed by a 1-year full warranty that safeguards against any defects in materials and workmanship. In case of any issues with the router within this period, the warranty can be claimed. The specific process for claiming the warranty is not mentioned in this document, but typically, it requires the customer to present proof of purchase and contact the manufacturer's customer service.
Craftsman 315.269210 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 50
crwdns2959996:0crwdne2959996:0 936
