crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2935069:02crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
315.26721
Background
The Craftsman Router 315.26721 is a woodworking tool produced by Sears under the Craftsman brand. This router is designed for use in various woodworking tasks, ranging from small to large projects. It is created for handheld use and can also be installed in a router table.
The Craftsman Router 315.26721 comes with a 10-amp motor that offers a no-load speed range of 16,000 to 27,000 RPM, courtesy of its electronic speed control. It also features a soft-start to prevent bit jerking at startup and an enclosed motor housing to reduce noise and dust. The router is equipped with a quick-release cam lock system for hassle-free depth adjustments and bit changes, and both 1/4" and 1/2" collets are included. The base of the router is made of precision-machined aluminum that can be rotated 360 degrees for accuracy. The router also includes adjustable depth stops for repeat cuts and a clear depth scale for better visibility. The start/stop switch comes with a lock-on button for continuous operation.
Technical Specifications
  • Motor: 10 amp, 1-3/4 peak HP
  • Speed: 16,000 - 27,000 RPM
  • Collet: 1/4" and 1/2"
  • Base: Diecast aluminum
  • Depth stops: Adjustable, with clear depth scale
  • Controls: Variable speed dial, lock-on button
  • Size: 10"L x 6"W x 7"H
  • Weight: 8 lbs
Warranty
The Craftsman Router 315.26721 comes with a 3 year limited warranty provided by Sears. This warranty generally covers any defects in materials or workmanship. To claim the warranty, you would typically need to contact Sears directly, provide proof of purchase, and describe the issue that you're experiencing with the router. It's important to note that warranties usually do not cover problems that arise from misuse of the product, so be sure to use the router as directed to avoid invalidating your warranty.
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2959996:0crwdne2959996:0 277
