crwdns2862668:0crwdne2862668:0
This wiki is missing a device image. Help improve this page by uploading one!
crwdns2935069:02crwdne2935069:0
crwdns2933307:0crwdne2933307:0
315.1746
Background
The Craftsman Router 315.17460, produced by Diehl Mfg Co for Sears, is a tool primarily designed for woodworking tasks. Its primary function is to assist in high-speed routing and edge shaping, among other wood-related applications.
The Craftsman Router 315.17460 comes equipped with a motor that spins the cutter bit at 25,000 rpm when there's no load. It incorporates a depth control feature that is adjustable in 1/64 inch increments, adding precision to the task at hand. The router also includes a clear plastic chip shield, and a built-in work light feature to provide better visibility in the working area. The router uses 1/4 inch shank cutter bits and is double insulated, eliminating the need for grounding. It also comes with a collet and wrenches for easy bit changes.
Technical Specifications
  • No-load speed: 25,000 rpm
  • Collet size for cutter bits: 1/4 inch
  • Depth control increments: Adjustable, with 1/64 inch increments
  • Safety feature: Clear plastic chip shield
  • Additional feature: Built-in work light
  • Insulation: Double insulated
Warranty
The Craftsman Router 315.17460 comes with a comprehensive warranty valid for a full year through Sears. The warranty covers the repair of the tool if it fails within the first year of ownership, with all costs for said repair being covered by Sears. However, it's important to note that the warranty period is shortened to 90 days if the router is used for commercial purposes. To claim the warranty, the tool should be taken to an authorized Sears service station where it will be inspected and repaired free of charge, provided the failure occurred within the stipulated warranty period.
Craftsman 315.17460 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2936753:030crwdne2936753:0 42
crwdns2959996:0crwdne2959996:0 1,022
