crwdns2935069:07crwdne2935069:0
crwdns2944766:0crwdne2944766:0
crwdns2918718:0crwdne2918718:0
crwdns2935091:0crwdnd2935091:0crwdne2935091:0
580752950
Background
The Craftsman Pressure Washer 580752950 is a gas-powered cleaning device primarily used for outdoor cleaning tasks. Its operation is facilitated by a 190 cc Briggs & Stratton engine which supports a maximum pressure of 3000 PSI. This pressure washer is equipped with five different quick-connect spray nozzles to help cater to various cleaning requirements. The device also features a 25-foot high-pressure hose and a detergent system that allows the use of concentrated cleaning agents.
The pressure washer is powered by a 4-stroke Briggs & Stratton 675 Series I/C OHV engine with a horizontal crankshaft orientation. This engine utilizes a Champion 692051 spark plug and runs on clean, fresh, unleaded gasoline with a minimum octane of 87. The device's axial cam pump can deliver up to 2.7 GPM flow rate, facilitating efficient cleaning. The detergent system of this pressure washer is designed to allow quick selection between two types of detergents. The device measures 24 inches in length, 20 inches in width, and 40 inches in height, and weighs 82 lbs when dry.
Technical Specifications
  • Model Number: 580752950
  • Product Type: Pressure Washer
  • Engine Type: 190 cc Briggs & Stratton 675 Series I/C OHV, 4-stroke, overhead valve design with a horizontal crankshaft orientation
  • Engine Displacement: 11.58 cu. in.
  • Spark Plug: Champion 692051, gapped to 0.020 in.
  • Fuel Type: Clean, fresh, unleaded gasoline with 87 octane minimum
  • Fuel Capacity: 1.6 quarts
  • Oil Type: SAE 30W detergent oil
  • Oil Capacity: 20 oz
  • Pressure and Flow Rate: Up to 3000 PSI and 2.7 GPM
  • Nozzles: Five quick-connect spray nozzles (0°, 15°, 25°, 40°, soap)
  • Hose: 25 ft high pressure hose
  • Detergent System: Two positions for detergent bottles with quick selection switch
  • Storage: Fold-down handle for compact storage, Onboard nozzle and accessory storage
  • Dimensions (L x W x H): 24 in x 20 in x 40 in
  • Weight: 82 lbs
Warranty
The Craftsman Pressure Washer 580752950 is covered by a 2-year consumer warranty. This warranty primarily covers defects in materials and workmanship. However, it is imperative to note that normal wear items such as nozzles, hoses, and filters are not under the coverage of the warranty.
Craftsman 580752950 Owners Manual
iRobot
crwdns2935283:009/24/09crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:0632crwdne2935297:0
crwdns2942667:0crwdne2942667:0 301
